Author Topic: Disappearing water  (Read 4489 times)
Offline rcsteuer
Re: Disappearing water
« Reply #15 on: July 28, 2023, 07:19:01 PM »
Again, thanks for the responses.
Chuck:  Yes, drilled the new thermostat when I put it in.  After the initial refill, I put the original bellows thermostat back in.  Same results with both. I did however, reinstalled the new 165 thermostat, as I'm not sure I trust the bellows unit - it's gotta be a few days old.
Binthere:  Yep, aware of water level being that low normally.  But this thing is drinking water to the toon of a gallon every couple hundred miles. That's a bucket load of water. Thanks for the tip.
Steve: Thanks for the clarification.  Makes more sense and I'll see if i can jury rig something to hold an overflow tank for testing. Will rap on the muffler too.
Ron:  It's not so much a pump bypass issue. The newer type thermostats do not sit low enough in the block on the flatheads to be submerged in water like the original bellows units (the thermostats are stacked on top of a spacer in the housing).  This results in an air bubble forming between the block and the thermostat until the engine nearly overheats. At that point, the thermostat will open but it's usually at a high temp.  To alleviate, drilling the 1/8" hole as pictured prevents the air bubble, allows some water to maintain contact with the thermostat, and keeps the temp closer to normal.  JB Weld, here we come.
