Author Topic: gas fumes, when running  (Read 11877 times)
Offline tow hook
Re: gas fumes, when running
« Reply #30 on: June 23, 2023, 11:48:26 AM »
after 10 mins of running it won't run with out  1/2 choke. with choke on i have a tad over 800 rpm. any thing less then 1/2 choke it dies here is pics of my set up. what to check next ? is it normal for carb base to have condensation on it ? temp is around 60-65 2day
idle set screw is 3/4 out, it s barely touching the stop. idle mixture screw 1 full turn out. wants to die when i rev it.
https://www.mywillyspics.com/image/lXLvl
https://www.mywillyspics.com/image/lXIpk
https://www.mywillyspics.com/image/lX4xt
 thanks for all the help.
Offline tow hook
« Reply #31 on: June 23, 2023, 11:50:54 AM »
Does your tach/dwell meter have a switch to go to either tach or dwell readings?  WHAT make and model is it?
posted a picture
« Reply #32 on: June 23, 2023, 02:09:29 PM »
I found a link that offers a manual access but pic is in black and white of instrument.  That said, it looks like there is one larger battery terminal clip, and a set "paired together" of different colors for smaller connections... if that helps any.
https://www.worthpoint.com/worthopedia/vintage-dixco-pro-tester-tach-dwell-1893336636
« Reply #33 on: June 23, 2023, 02:27:23 PM »
Second and third effort finally found a clear hook up pic.  See attached...  Black to ground, Green to coil (dist side), and Red to battery.
Offline tow hook
« Reply #34 on: June 23, 2023, 03:08:56 PM »
thanks for looking that up....   that's how i have it hooked up.
sat i will pull it out side and try again. hope it will run with out choke
« Last Edit: June 23, 2023, 03:12:04 PM by tow hook »
« Reply #35 on: June 23, 2023, 03:42:25 PM »
Vacuum reading? You may have to adjust the mixture screw out a little. Don't be afraid to experiment a little. The worst that can happen is it will shut off.
Offline tow hook
« Reply #36 on: June 26, 2023, 11:30:22 AM »
i tested the fuel pump as per the manual. i have 8 inches of vacuum on the wipers and 3 psi on the fuel.  so we are in spec.   it runs so bad i have to push it out side to run it now. to much fumes to keep in the garage
 what are the odds i have a bad float ? or other bad part in the carb ??? and i have had it shut off on my a few times for sure
Offline tow hook
« Reply #37 on: June 26, 2023, 02:55:18 PM »
i got the idle set screw turned up, idled ok, got it oit side.  idles ok. choke is off. adjusted dist.  vacuum is now in the green so 17/18 inches . dwell meter doesn't rise with rpm   ???  i upped the throttle a few times seems snappy. dwell meter barely rose. so i'm assuming the rpms it's showing me isn't correct. going to work. mess with it tuesday still don't know my rpm. but i feel better
« Reply #38 on: June 26, 2023, 04:15:21 PM »
THE NEXT STEP...Do you have an iPhone? We can do Facetime and I'm making a no-charge house call to help you. 336-963-3605 0700-1900 seven days a week. Call me.
Offline tow hook
« Reply #39 on: June 29, 2023, 02:47:48 PM »
i got another meter to use, ( i did get one on ebay,it will be next week till i get it ) and the first dwell tach was right  :( i have 800 rpms. any lower the 780 and it stumbles, and stalls. i've tryed re setting the idle set screw, and the idle mixture screw, in different combos . and 780 is the lowest i can got before the vacuum gauge goes all over (  up and down very fast , then a stall ) i assume that the carb comes off, and i have a float issue? i'm thinking to much fuel ?
 an eye phone ? na i'm old fashion, i got a flip phone. off to work in a bit.   maybe fri morning if your avl ? i'll check the board here before i call you.  thanks....
 hope these pics help. at the 780-800 range it purrs, the vacuum is steady
https://www.mywillyspics.com/image/lXMQc
https://www.mywillyspics.com/image/lXZsF
« Reply #40 on: June 29, 2023, 03:49:00 PM »
I'm here all day. 0700-1900, seven days a week.
Offline tow hook
« Reply #41 on: June 30, 2023, 11:34:09 AM »
thanks, i will reach out after lunch.
 i did read the service manual today, and learned about the low speed circuit and perhaps i have some carbon build up in the throat of the carb. or some of those tiny passages need cleaned
Offline tow hook
« Reply #42 on: June 30, 2023, 02:57:28 PM »
thanks rick for a huge hand in helping getting the idle down were it should be.
it's around 640 -670 rpm at idle. i really thought the carb was coming off for a cleaning of the low circuit passages. rick knows carbs and how to adjust them , even over the phone with a guy like me.
 thanks again
« Reply #43 on: June 30, 2023, 04:15:44 PM »
Happy trails my friend...
« Reply #44 on: June 30, 2023, 05:13:00 PM »
Whew!  Well done!
On to the next challenge!
