Author Topic: 1961 CJ3B "Gator"  (Read 21674 times)
Offline Shark49
Re: 1961 CJ3B "Gator"
« Reply #120 on: September 02, 2025, 07:14:36 AM »
Transmission question.  I have an overdrive on my 3 speed.  Works great.  However, when I am driving and I let off the gas it often shakes and rattles.  Is that a bad bearing?  Under throttle it's fine if a bit noisy.  I emptied and replaced the gear oil.
« Reply #121 on: September 02, 2025, 08:41:37 AM »
How did you determine it was the OD?  Have you applied tension (forward/rear/side-to-side) to each shifter to see if the rattle changes?
Offline Shark49
« Reply #122 on: September 02, 2025, 10:46:13 AM »
I was just stating I have an OD.  The shifters rattle but its like a whole tranny thing when I lift off throttle and then reapply it will vibrate whole jeep
« Reply #123 on: September 02, 2025, 02:15:09 PM »
Ok.  How about shifting out of OD into direct drive.  Same?  This is in 2WD, right?
That description also makes me wonder about your U joints.  Especially when you say it vibrates the whole jeep.  May be hard to twist by hand but another way is to jack up wheel and turn the tire back and forth.  Watch the yokes to see if there's movement between the yoke and driveshaft ( both - at the transfer and differential).  This works for front or back. Lifting both wheels on an axle will just get the other wheel spinning.
If you can rule out the U joints, there may be some other things to look at.
Offline Shark49
« Reply #124 on: September 04, 2025, 06:34:29 AM »
YEs 2wd.  yokes are brand-new but ill check that.
« Reply #125 on: September 04, 2025, 10:09:34 AM »
Also check phase.
« Reply #126 on: September 04, 2025, 10:54:24 AM »
QUESTION... When did you start noticing it?  Was it after any major "changes", or "incidents" (like off roading)?  Pinion angle too extreme, bent drive shaft, worn gears in transmission or OD, etc.
Offline Shark49
« Reply #127 on: September 09, 2025, 04:38:56 PM »
No big changes just getting it on the road for my first time.  The transfer case handles rattle some but there's something else going on when alifting off throttle and then back on with slight throttle the whole things vibrates
« Reply #128 on: September 10, 2025, 08:24:43 AM »
This may be a strange question, but.. Are all of the tires the same size and condition, or if not, might it be that when you take it off "load" and then power back the differences "translate" back thru the tires to the drivelines trying to "catch up" at different speeds or conditions (like balances, tread types, wear factors, alignment, etc)?
Offline Shark49
« Reply #129 on: September 11, 2025, 03:11:31 PM »
all the same and radial tires at that.  Im going to check all of the mounts etc. for loose nuts.  But it feels as if something is off balance but under load it's fine.
« Reply #130 on: September 11, 2025, 03:23:27 PM »
Can you recreate the vibration with the vehicle up on "Jack stands under the axle housings" for FREE WHEEL spin and proper "ride position"... spinning the wheels with load and "no load"... and with the assistance of a helper make observations that way from underneath?  Maybe see if just one axle does the vibration, or elewhere, like a drive shaft, or the tranny itself.
