Author Topic: steering slop/ dead space in the wheel  (Read 6204 times)
Offline Bruce_W
Re: steering slop/ dead space in the wheel
« Reply #15 on: March 07, 2022, 09:23:36 PM »
  Firm:  When you are turning it with, say, 15 ft lb. and it suddenly stops, and you get the feeling that 90 ft. lb. more will not move it any further. Like where you have it set now. Then back it off.
BW
Offline tow hook
« Reply #16 on: March 09, 2022, 11:07:43 AM »
....define firm......to me firm maybe over tighten it by what some one else thinks is firm. i didn't think it would hurt to ask what others had done......having a live person can be way better.
That is what I call a legitimate question.  It's not simple defining something you "feel"  vs. what can be read on a dial....
At the beginning of the SM, there's a passage that states the information is intended for those familiar with servicing.  So, yeah, some needed information is missing but now we have the internet.
My philosophy is to ask away.  It really can't hurt.
To me, firm in this case, is (if I could get a large screw driver on it) tight with both hands and a few choice words.  Been there done that.  However, if you use the correct tool:
https://www.amazon.com/Stanley-Proto-J5446A-2-Inch-16-Inch/dp/B002FCP4DO
https://www.thecj2apage.com/forums/drag-link-tool_topic20409.html
Firm becomes contact with maybe less than a 1/4 turn (maybe just snug).  What I get out of that is you snug it down to ensure everything is seated and then back out to allow the springs to do their job.  I think that if you back out too much to where the parts are loose is too far.  Firm = just a little bit of spring compression.
Others with more experience could evaluate this and maybe expand on the technique they use.
 thanks, an i do have the tool, make life very easy ;D
Offline tow hook
« Reply #17 on: March 09, 2022, 11:08:24 AM »
BW
thanks, maybe i pull down the grease/ dust cover, and try that
Offline Bruce_W
« Reply #18 on: March 09, 2022, 05:52:17 PM »
Well dont go out there with your torque wrench and start trying to put 105 ft. lb. on it. Im not saying you would do that but somebody might. You understand what I’m saying?
BW
Offline tow hook
« Reply #19 on: March 12, 2022, 05:17:01 PM »
BW
Yep, I did turn it a bit more. The pitman arm ball moves just a tad now in that rear socket. When the wife is home I ll have her work the wheel, it looks like I have play at the bell crank area. So I ll try an pin that down.
