Hi guys
I’m trying to find a pic of the passenger side wiper motor which was an option for the CJ3A. Currently it has the manual wiper for the passenger side.I have the Willys part number WO-672778 and the Trico part number S-616-1. I have two or three motors but there are no markings on them other than patent numbers. Some have straight connection barbs and one is curved. One has a manual wiper attachment, l’m guessing that one could be for the driver side.
Doing some searches I have found a couple of post that would have shown the motor but the images had expired.
I would appreciate any pics of your setup or documentation.
Thanks.... Bill
Both blades are inward and down when at rest.
As you noted you must have correct wiper motors in proper location for that to happen.
The “ at rest†position of the motors is not adjustable.
SF 616 should have small chrome arm for manual swing.
Otherwise it is some other TRICO model
That allows you to clear the windshield with heavy snow build up.
Had to copy/paste to see some posts (that's the only reason I copied them here). I tried to find some images that were here. I also compared them to a CJ3B wiper motors too.
From what I can tell, one motor has a curved inlet/barb (driver's I believe) and a straight inlet/barb (passenger's I believe). I found some good close-ups of Tumbleweeds here:
https://cj3apage.com/Forum/index.php?topic=1193.msg9412#msg9412Scroll down to near the bottom. I can't tell if that vacuum line/hose is the correct routing but it seems logical.
This is athawk11's with some close ups confirming curved on the driver's side:
https://cj3apage.com/Forum/index.php?topic=4514.msg36782#msg36782There's got to be a "Y" or "T" connection of some type - to split off and connect to the passenger wiper motor, but I don't know what it looks like nor exactly where it sits. If the driver's wiper motor has the curved inlet/barb, it would suggest the split would be under or towards the left of the driver's motor.
Comparing these motors to the 3B, they appear the same. BillT, the part number you listed matches the part number in my copy of the CJ-3B Parts Manual for the passenger side. And like OT stated, the one I have on mine has the little chrome arm on the back of the shaft to "help" the wiper when needed.
