Author Topic: All Power lost  (Read 5980 times)
Re: All Power lost
« Reply #15 on: June 16, 2021, 01:00:30 PM »
Bob,
You've used this setup for a while, right?  For a period, it worked until you got home from the reunion?
From your first post:
Quote from: bob3b
I took the wires off the starter switch (which I actually have wired to activate the solenoid) and just put them together to try to start it. It trips the breaker
Later, you suspect you've narrowed it down to the ignition switch itself.  I didn't catch whether you had a 3-postition ignition switch that's acc/off/on or if you have the later style with the momentary "crank" position (doesn't need to be used if the floor switch is used).
That test where you disconnected the switch and touched the wires together gave you the same problem popping the cb.  Somebody didn't re-wire your starting circuit while you weren't looking, did they?
Offline Bob3b
  • I have a Jeep sickness!
Re: All Power lost
« Reply #16 on: June 18, 2021, 07:28:39 PM »
It was a bad post on the ignition switch. I got a new one today and when I took the old one out the post was loose. It works as it should now. My guess is that that post must’ve been grounding out.
Bob3b
1953 CJ3B
1949 Jeepster
1947 Empire Tractor
Re: All Power lost
« Reply #17 on: June 18, 2021, 09:28:28 PM »
A happy ending!  Nice.
