Author Topic: My 54 3B build  (Read 7958 times)
Offline Sammydida3B
Re: My 54 3B build
« Reply #15 on: May 18, 2021, 09:03:11 PM »
My back bumper and spare tire carrier is almost finished. It's coming out pretty good.
« Last Edit: May 18, 2021, 09:05:19 PM by Sammydida3B »
Re: My 54 3B build
« Reply #16 on: May 18, 2021, 10:38:42 PM »
That's a stout looking bumper.  Will the pivot have a grease fitting?
Ron
   It had one but I decided that I probably wouldn't be putting very many miles on the bearings (considering the fact that they would turn about a quarter of a revolution once in a while) I deleted it.
   It is a very stout bumper. I used 3" victolic or in English "fire suppression pipe". It's about 1/4" thick. Heavy but not too heavy. Below is a shot of the front bumper.
« Last Edit: May 19, 2021, 05:17:06 PM by Sammydida3B »
Re: My 54 3B build
« Reply #17 on: May 19, 2021, 07:26:19 PM »
To me, "lack of frequent use" would be more of a reason to make sure it is greased to keep condensation out of the bearing from sitting idle in an air pocket.  An "ounce of prevention", if you will.  Nice work on both ends and in between too.
Offline Sammydida3B
Re: My 54 3B build
« Reply #18 on: May 19, 2021, 08:59:12 PM »
SteveKfl
    You might have a good point there. I'll check it after some time and if there's an issue I'll clean things up and drill a hole. Thanks for the positive feedback. It's been challenging at times but always rewarding. It not the destination but the journey.
Offline Sammydida3B
Re: My 54 3B build
« Reply #19 on: May 23, 2021, 09:38:34 PM »
Well the 3B is finished. I guess it's time to do the 2A.
« Last Edit: May 24, 2021, 06:22:13 PM by Sammydida3B »
Offline Sammydida3B
Re: My 54 3B build
« Reply #20 on: October 30, 2021, 08:27:21 PM »
Update: Wow!!!  Five months ago I said that the 3B was finished. Here it's the end of October and after four engine swaps it is running very well. The 231 Odd FIre is really strong. What a super fun little jeep.
« Last Edit: October 30, 2021, 08:51:56 PM by Sammydida3B »
Offline tow hook
Re: My 54 3B build
« Reply #21 on: April 12, 2022, 01:56:43 PM »
Note Contact info is Florida...
CONTACT US
1319 Green Forest Ct Unit 401, Winter Garden, FL 34787
1-407-614-1141
info@somarmotor.com
when i called to day they said he didn't have one that fit the rope channel, i see that they do make them. so i'll check around for one instock. thanks
