Author Topic: WTB- Ramsey DP-1 PTO parts needed  (Read 1368 times)
Offline cjbilly
« on: March 05, 2021, 03:43:04 PM »
WTB / ISO- some replacement parts for our Ramsey DP-1 PTO shifter. Hope to source some of the bearings and seals locally if part numbers and manufacturers are available. If you don’t have loose parts, a parts broken/ damaged PTO shifter would likely work.
BTW- I have already contacted Herm- no spare parts at this time. Thanks!
1984 CJ7
1989 MJ
1946 CJ2A with Supersonic motor (future build)
1948 CJ2A with rear PTO
1955 Sears/David Bradley Trailer
1955 CJ5 with rear PTO
1954 CJ3B with trencher and front blade
Re: WTB- Ramsey DP-1 PTO parts needed
« Reply #1 on: March 06, 2021, 12:11:44 PM »
cjbilly,
Don't have any experience on PTO's.  I know (have seen) shops measure for bearings so I wonder if you had those a shop could find replacements.  That idea confirmed here (Wes Knettle's quote):
https://cj3b.info/Tech/RamseyWinch.html
At the very least, I offer the below to hopefully spur more input - from those that may actually have some numbers for you.
Here's a website that has good info on multiple PTO's:
http://www.48cj2a.com/ptos.htm
It shows the DP-1 as twin stick for CJs.  I wonder how much difference there'd be on bearings/seals from a similar model (PT-1).
A link on the above page takes you to WillysTech page for PT-2:
http://www.willystech.com/wt/pto/ramseypt2f/ramseypt2f.htm
scroll to the bottom where he's added info on PT-1 from Tom Jacoby.  Hopefully, there may be some common parts.
Offline cjbilly
« Reply #2 on: March 06, 2021, 01:23:15 PM »
Thanks for getting back with me Rus.
What bearings and seals that we could read are already at the Motion Industries for pricing and availability. Luckily, we have found some addition info elsewhere.
Just was hoping someone had already gone this route and could share their findings/part numbers. We have saved our parts list on the several PTO gear boxes we have redone for our own jeeps. Wait till someone has to buy replacement parts for the PTO rear driveshafts. ;)
1984 CJ7
1989 MJ
