Author Topic: Gears too worn or replace?  (Read 2647 times)
Offline LKap
  • Jeep Fanatic
« on: July 19, 2020, 11:00:31 AM »
So I committed the cardinal sin while taking out the transmission by not wiring the main shaft. Yep - clink, clink and all the needle bearings fell out. I’ve always wanted to rebuild a T-90 so here we go. I have everything apart and the counter shaft and low/reverse gears look pretty worn out. Should I replace?  FWIW before I took it out the transmission worked great. The only reason I was taking it out was to get at the clutch/flywheel.
Re: Gears too worn or replace?
« Reply #1 on: July 19, 2020, 08:19:02 PM »
I would...
...replace 1st/reverse and clean up and smooth the teeth on the cluster gear.
For me, 1st/reverse is just too used up for my liking.
Offline LKap
  • Jeep Fanatic
« Reply #2 on: July 20, 2020, 12:30:36 AM »
Thanks. I was prepared to replace both but you may have just saved me about $175.
Offline JeepsterJim
« Reply #3 on: July 21, 2020, 02:07:07 AM »
you have the opportunity to upgrade to a T-90C trans gear set up which will give you a lower first and second gear.  you simply need to replace the input gear and cluster gear. Novak has a kit for it.
Offline OnlyOneDR
« Reply #4 on: July 21, 2020, 05:34:52 PM »
Great info; I read up on this after reading your post and it sounds like combined with an OD the gear splits work out nicely.  I have not cracked my T90A open yet but now it sounds like I have a reason to!  Of course that will mean getting an entire rebuild kit for it...
1950 CJ-3A #37751 In Pieces
Offline LKap
  • Jeep Fanatic
« Reply #5 on: July 21, 2020, 10:09:50 PM »
Certainly sounds like a great option. Unfortunately it’s a bit cost prohibitive at this point. I ordered a new 1st gear and small parts kit from Novak. Maybe I’ll do that conversion in the next rebuild!
