Author Topic: Cleaning Serial Number Plate  (Read 1810 times)
« on: June 03, 2020, 04:52:13 PM »
Looking for some ideas on how to clean the embossed aluminum serial number plate on my CJ3B. I have tried carefully scrubbing with an old tooth brush, and even lightly scrubbing the edges with a scotch-brite pad, but this is as good as I have been able to it. Ideas?
Re: Cleaning Serial Number Plate
« Reply #1 on: July 09, 2020, 12:18:34 PM »
Very late response here,
But if you have a cheezy Sears sandblast kit, you can use baking soda as a medium. I've used this stuff when "sand" blasting carburetors. It's very gentle, but will clean aluminum very nicely.
I stick the suction tube right in a big bag of baking soda (big bag of baking soda purchased cheaply from Costco, BJ's, whatever). Of course do a test on something first!
I bought my sandblast kit from sears for 50 bucks some years ago, maybe harbor freight has them now?
Good luck!
« Reply #2 on: July 09, 2020, 06:02:23 PM »
Thanks for the reply! This plate is so thin and fragile, I decided to just clean it as well as I could and reinstall it like it is. Funny story, about a week or two after I installed the plate, I was sitting down taking a break, and I was looking at the jeep, I thought, that serial number plate looks much better than I thought, much shiner. I looked closer and realized I had installed it backwards! I turned it back around and now it looks OK, not as shiny as the back side!
« Last Edit: July 10, 2020, 07:27:57 PM by Chuck W. »
Offline ojgrsoi
  • Learning about the L134
    • The Jeep DJ5
« Reply #3 on: January 14, 2021, 10:52:40 AM »
Did you happen to try the baking soda with the tooth brush.  I know I am late to the party.
Mark
1949 CJ-2A
2025 Jeep Gladiator Nighthawk
1969 Dodge D100
*50 VJ,60 CJ5,70 DJ5 Postal Dispatcher,66 FORD M151A1,51M38,73 IH Cub154 LoBoy,70USA DJ5 LHD,67 CJ6,78USN DJ5F LHD,79 DJ5G,*All SOLD
« Reply #4 on: January 14, 2021, 11:29:20 PM »
Thanks, I did, indeed, try baking soda, polished the aluminum but didn't remove the dark areas. Acetone seemed to do the best, followed with a good coat of car wax.
