Author Topic: project: crunchy roll (53 cj3a)  (Read 18446 times)
Offline Squishymonster
Re: project: crunchy roll (53 cj3a)
« Reply #75 on: September 02, 2021, 03:11:29 PM »
I wanted to rebuild my rear seat mounting system and frame so that it could be easily removed for hauling hay with the tailgate down. I finally got a workable tubing bender that can handle up to 1 inch. I designed a custom frame that uses the original mounting points in the bed, and fits in a similar fashion. I made custom rear pins or studs that bolt into the rear seat retaining clip holes - I don't have the original retainers, and didn't want to spend what "they" are asking. So I made the studs fit up inside 1 inch tubing and they will use 1/4" through-pins to secure.
Everything came together really nicely, and I'm happy with how the CJ5 vinyl seat mounts to it. I could not retain the tilt forward functionality - or at least not without more effort than I wanted to expend, but it is fully removable without tools. It sits slightly higher and further back than previous, so I'd say leg room is maximized without having the seat in a weird spot.
I'll get photos soon.
It's all back together except I still need to reattach the muffler - I need to come up with a better way to mount that too. I had the compression fittings on there that kink the outer tube, and the stupid things were jammed together permanently. I had to cut a slot in one tube to get them apart, and I want to make that easier to get apart for next time I need to do maintenance under the bed.
I also made some custom rubber body mounts for the two bed mounts - I think they are the only two functioning on the whole vehicle ATM.
I pulled / repaired a minor but annoying dent and split in the rear left quarter panel that was contributing to a very slight amount of the rear body sag. I have nearly all of the major body damage straightened out at this point - at least rouged in, and I'm really happy with it. I think I'm 100% ready for the Best Top install, and just in time for Fall.
In my efforts to hunt and destroy rattles, I pulled the left and right windshield frame topper strips out, and they are being repaired. One was screwed in, and the other was held on by one weld, so it was jiggling all the time. I mangled one of them a good bit, but almost have it back into shape. It's going to require some MIG finesse to repair properly though - some really light beeds so I don't have to destroy the track with a grinder afterward.
I'm feeling like next steps might be repairing some of the bigger rusted spots in the floor - my 2.5yo daughter loves to climb around in the jeep while I'm working on it, and I'd like to get rid of things that could get her snagged up.
« Last Edit: September 02, 2021, 11:56:35 PM by Squishymonster »
