My Willys 3A and 3B Community
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
News:
Welcome everyone from the CJ3B!
Willys is a big family.
Home
Help
Search
Downloads
Gallery
Login
Register
TECH FAQ SECTIONS
EVERYTHING ELSE, General tips
Emergency Brake & Speedometer cables routing
« previous
next »
Reply
Print
Pages: [
1
Go Down
Author
Topic: Emergency Brake & Speedometer cables routing (Read 3189 times)
Andrew
Project Jeep (Newbie)
Still Plays With Jeeps
on:
September 03, 2019, 12:25:28 AM »
On a 3A, what is the correct routing and clip attaching points for the emergency brake and speedometer cables? Any tips from experience or precautions concerning these also appreciated Thank you
Logged
Rus Curtis
Willys Guru
Retired
Re: Emergency Brake & Speedometer cables routing
Reply #1 on:
September 03, 2019, 09:52:06 AM »
Andrew,
I found several posts that will help on the Hand Brake Cable. They show some of the attachment points for the cable. The upper (firewall) attachment and lower (crossmember) keeps the cable housing secure which allows you to pull the inner cable when applying the brake. The center clip just keeps the housing out of the way and up against the bellhousing.
https://cj3apage.com/Forum/index.php?topic=4006.msg34159#msg34159
This one has a unique attachment at the bellhousing:
https://cj3apage.com/Forum/index.php?topic=3839.msg32771#msg32771
This is the one I like best as it shows all the clips (this is for a 2A and match the 3B clips so I'd assume there is no change for the 3A):
https://www.thecj2apage.com/forums/ebrake-clip_topic36651_post344215.html?KW=cable+clips#344215
To me, the center clip resembles a large "brake line" clip but as proven, anything that will hold it to the bellhousing will work.
For the Speedometer Cable, I found an image on this post that shows a clip holding the cable against the firewall just above the starter:
https://cj3apage.com/Forum/index.php?topic=3181.msg26507#msg26507
Another image of Wade's '55 under the Oil Bath Breather showing the same clip on the firewall:
http://cj3b.info/Photos/Owners/Wade/CurtisPhotos/AirCleanerBottom.JPG
I'm not sure about further down, but I just laid it up in the C channel.
Logged
Reply
Print
Pages: [
1
Go Up
« previous
next »
TECH FAQ SECTIONS
