Welcome to our new forum software.We are now using SMF instead of YaBB.
Hi Dinesh,I don't have a spare.� I just have this one.� I'm going to hang on to it for now.� These are a little crude, but should give you most of what you need.� Whatever you build, it doesn't need to be this precise.� �A square chunk of metal with three drilled holes and different size bolts would work.� Even an "S-shaped piece of flat steel could work.
I was thinking heavy wall square tube stock with interior 1/4 ID tube spacer/support for the middle bolt hole..
