Author Topic: New 3A (to me), Trans Cover & Seat Questions....  (Read 9635 times)
Offline SteveV
Re: New 3A (to me), Trans Cover & Seat Questions....
« Reply #15 on: January 08, 2016, 08:46:35 PM »
Specialty, Thanks  I will be in touch on the seats.
Today was good progress, was too busy for pictures, i will post some tomorrow.
Kirk Nice BOX!  Gave me a neckache checking it out but worth it.    Yellow wouldn't be my preference, more of a green.  The body was painted when I bought it a couple weeks ago.  I'm certainly not complaining, it's growing on me.
macrisel Thanks for the info on the trans cover.  Mine ended up getting cut up today, I will post pictures tomorrow.  I also need to put shims the trans mount a bit more so the trans lays a little lower.  Someone had bolted down the body and the trans bent the body a little from hitting.
Offline SteveV
« Reply #16 on: January 09, 2016, 02:45:09 PM »
Here is the progress on the cover.  Not quite finished but seems to be going good.
The fenders seem to line up with the grill & hood.  ::crossing fingers::
Only drawback with doing this & not moving the body is the rear goes past the frame a little bit. (as another member has pointed out)
« Reply #17 on: January 09, 2016, 06:08:07 PM »
Steve,
Grill, fender, and tub alignment are far more important than the tub hanging off the rear a bit.  If it ever ends up bothering you, you could always remove the rear bumper and shim it out a little.
Offline specialty
  • 1952 CJ3A
« Reply #18 on: January 10, 2016, 06:47:20 AM »
Steve,
Grill, fender, and tub alignment are far more important than the tub hanging off the rear a bit.� If it ever ends up bothering you, you could always remove the rear bumper and shim it out a little.
Good idea. This is one of those things that Steve can do and nobody will know the difference except himself and possibly a few novice if cleverly disguised.
« Last Edit: January 10, 2016, 06:48:56 AM by specialty »
Offline SteveV
« Reply #19 on: July 12, 2016, 06:18:34 PM »
Small update....  Finally getting back to putting together the 3A.  Some issues, but so far, so good....Still deciding on Seats.  I might just pounce on these and make brackets.  Any have aftermarket seats that they made brackets for??
https://www.amazon.com/Rugged-Ridge-13400-01-Standard-Black/dp/B001FAGKQC
Short video---
https://instagram.com/p/BHKLYtUhIFW
