Author Topic: wiring question  (Read 3238 times)
Offline specialty
  • 1952 CJ3A
wiring question
« on: May 16, 2016, 10:32:32 PM »
I have 2 tail lamps with 1157 bulbs. i want to run tail lights,brake and signal off the same 2 filament bulb. Anyone know where I can get a good diagram to hook up the signals? I can do the tail and brake with no problem but not sure about how to get the turn to work. thanks
Re: wiring question
« Reply #1 on: May 16, 2016, 11:04:37 PM »
Offline specialty
  • 1952 CJ3A
Re: wiring question
« Reply #2 on: May 17, 2016, 08:38:48 AM »
I guess first I need to get the signal light switch. Can the rear lights flash using single 1157 bulbs while still having tail and stop lights? I think somehow the signal light is wired in with the stop light and cancels the stop when turned on? I have a single 1157 bulb in each tail light on my 3A and was thinking to make things much more simple I could install another socket for another smaller bulb in each housing for the signal purpose. Does this make sense or am I over reacting?
« Last Edit: May 17, 2016, 08:41:35 AM by specialty »
Re: wiring question
« Reply #3 on: May 17, 2016, 09:03:02 AM »
I have signals on my 55 CJ-5 and it uses the single dual-filament bulb in the tail lights...I'm not sure whether it uses the stop light filament or the tail light filament as the signal...but I wired it as shown in the diagram and it works...
I'd have to go look but I think my switch is a Signal-Stat 900..
« Last Edit: May 17, 2016, 09:39:05 AM by 1955CJ-5 »
Offline JimVillers
Re: wiring question
« Reply #4 on: May 17, 2016, 10:08:30 AM »
My new wiring harness with a provision for turn signals came with a separate brake light wire for each side.  The turn signal switch can then use the brake light for either braking or signaling.  It uses the standard 1157 bulb.
Jim Villers
Virginia Beach, VA
Offline specialty
  • 1952 CJ3A
Re: wiring question
« Reply #5 on: May 17, 2016, 10:16:41 AM »
I am doing my own harness since it fairly simple other than the rear signals using a 1157 bulb. I thought about making up another socket and spot weld it in the light housing but since it will work I just need to do it. However I did run 4 wires back to my tail lights in case I needed more wires to make it work. I think once I get the signal switch it will see have the provisions to accomplish that.
Thanks
Re: wiring question
« Reply #6 on: May 17, 2016, 12:57:56 PM »
The brake and the flashing signal use the same filament in the 1157 bulb.
When at a stop light with brake pedal pushed, and with the left turn signal flashing, your driver side will be using the filament to signal the turn and the passenger tail light will be using the filament for the bright steady brake light mode.
The running lights use the other filament in the 1157 bulb.
This is why you don't need separate bulbs.  The function is built into the dual filament bulb.
A flasher module is needed in the equation to make all of this work.
Hope this helps.
Hawk
Offline specialty
  • 1952 CJ3A
Re: wiring question update
« Reply #7 on: May 25, 2016, 03:05:18 PM »
problem solved. When I got the turn signal switch it makes it easy. thanks
Ron
