Author Topic: Fuel Line Fitting  (Read 2646 times)
Offline JimVillers
Fuel Line Fitting
« on: March 24, 2016, 02:15:27 PM »
Another item that I am trying to figure out is the routing of the fuel line.  I have the pre-formed line that "looks perfect".  Of course it cannot be installed without cutting the line or removing the steering box or something else.
I located this image on the routing of the line.  It does not look possible to use the "correct path" because of the clutch pedal.  Are either of theses paths correct?
Jim Villers
Virginia Beach, VA
Re: Fuel Line Fitting
« Reply #1 on: March 24, 2016, 02:53:20 PM »
[size=12]While the dashed line is the correct factory set up, the other route is easier and the plan of choice for most. Back then, no one expected that fuel line would need replacement.[/size][/b]
« Last Edit: March 24, 2016, 02:54:18 PM by scoutpilot »
Offline Mike S
  • CJ2A SN CJ2A114542
« Reply #2 on: April 09, 2016, 04:01:40 PM »
Can anyone tell me where the clamps for the fuel line are located and attach?
Life is short
Quit your job
Turn off the TV
Go outside and play
« Reply #3 on: April 09, 2016, 06:54:56 PM »
Offline Mike S
« Reply #4 on: April 10, 2016, 03:52:18 PM »
Thank you. Very helpful.
Life is short
Quit your job
Turn off the TV
Go outside and play
