Author Topic: Lack of power from low compression?  (Read 10822 times)
Re: Lack of power from low compression?
« Reply #15 on: March 03, 2015, 04:56:40 AM »
[size=12]Yes. Indeed. Glad you found it.[/size][/b]
« Reply #16 on: March 03, 2015, 08:02:25 AM »
I hate reading success stories like this.  Not really.  Always makes me think I might be able to get a bit more out of mine.
Non the less, good job........glad you woke it up.  I bet it put a huge grin on your face :)
Brett
« Reply #17 on: March 03, 2015, 01:43:35 PM »
� Always makes me think I might be able to get a bit more out of mine.
Brett
I was in a similar place at one time.� I had nothing to compare to.� Just figured this is what I get from a 60hp engine...Until I went to the first Fall Colors Tour.� I was finally able to see where I was, compared to the others. My Willys had an obvious disadvantage.� Less power on the climbs. Less speed on the straights.
After that first year, I knew I had some work to do, so I replaced my timing chain. (GPW engine)� Rebuilt a Carter and replaced the Solex.� Re-indexed my oil pump so I could time the engine properly.� While driving my neighborhood, I could feel the difference.
Year #2...Fall Colors Tour.� The improvement in performance was like night and day.� I was now pulling away from people on the climbs, but good speed on the straights?� Well it did fine, until an MB passed me when we were on a flat paved road. :(� I was even at full throttle. He still drove by me.� I figured he had an Over Drive.� Nope.
That's when I learned about the different axle gear ratios in an MB.�
My 3A can out climb an MB all day long, but he's going to pass me easily while cruising a flat paved road. ;)
Different gear ratios = trade offs.� I think I like my climbing ability more.� Especially at the top of Tin Cup Pass. ;)�
Tim�
« Last Edit: March 03, 2015, 01:45:52 PM by athawk11 »
« Reply #18 on: March 03, 2015, 05:25:48 PM »
Nice, I might get to experience those same circumstances if I can get out there thise year with you all.  Trying to even get to John's BlackHills run in the spring if all works out.
Brett
« Reply #19 on: March 03, 2015, 09:48:32 PM »
Bretto,
It would be great to finally meet you.  I hope you can make it.  I might be able to pull off the Black Hills Run too.
