Author Topic: Battery Disconnect Switch  (Read 10393 times)
Re: Battery Disconnect Switch
« Reply #15 on: January 10, 2014, 10:34:16 AM »
Thanks Zeked....I understand what the relay does and thanks for the explaination!.....but my plan is to run all the power, ignition as well as the power to crank the starter through the disconnect switch...my 3a has no solenoid, it's a "kick start"..
I have a Lucas disconnect switch, Austin Healey used them and I have one on my MG...but it is 12 volt. At six volts the same number of watts draws twice the amps, so I'm pretty sure the switch won't handle it....
I may have to buy one of those big disconnect switches, or just forget about the whole thing....
Offline johnrb3b
    • Jeeps and stuff
« Reply #16 on: January 10, 2014, 11:11:10 AM »
If it were me, I'd mount it above the passenger's left foot, clear of any heater and the air cleaner, high enough under the dash to be out of sight.
Shortest distance from battery to switch to starter.
Then size wouldn't matter.
« Reply #17 on: January 10, 2014, 11:18:04 AM »
That is the location I was planning......my thought was to mount it through the firewall so the cables would still be in the engine compartment and the switch lever in the passenger compartment. .
But, maybe I could mount it on that dash brace...but then there would be longer cables to the switch and starter....
Offline Birddog7
  • Still Plays With Willys
« Reply #18 on: January 10, 2014, 11:19:57 AM »
FYI, On the 2A forum, a member Freddy is using a mechanical cut off switch. It's under " It was your entire fault " page 4. It has some really good pictures of how he installed it.
Birddog7
1945 CJ2A
1946 CJ2A
1948 CJ2A
1948 CJ3A
1956 CJ3B
Offline ZekeD
« Reply #19 on: January 10, 2014, 11:42:22 AM »
Oops, sorry about the confusion.  Maybe too much beer?
For positive disconnect look at marine switches from West Marine . Com.     If you can handle the size a "Perko" switch is made for that.
Zeke
Offline ZekeD
« Reply #21 on: January 10, 2014, 03:09:48 PM »
Well 800A should cover it.... A little pricey but now that you have the model # perhaps you could trim some off of that.   Good Luck
Zeke
« Reply #22 on: February 16, 2014, 08:55:59 PM »
It took a while, but I finally got the switch, now I need to find a place for it......
« Last Edit: February 16, 2014, 08:59:32 PM by 1955CJ-5 »
Offline ZekeD
« Reply #23 on: February 17, 2014, 12:02:05 PM »
That should do it!     Very pretty, too.
Zeke
« Reply #24 on: February 17, 2014, 07:41:05 PM »
It's beefy enough....I may have to break down and drill a hole....I hate to drill extra holes.. >:(
