Author Topic: Hi / Lo range in 2WD  (Read 7642 times)
Offline duffer
  • Just old
Re: Hi / Lo range in 2WD
« Reply #15 on: December 07, 2013, 08:53:48 PM »
It don't sound like the Warn Loc-O-Matics are a good choice if they lock and unlock on their own.
That is exactly what they are supposed to do.  With an open front where one side of the axle isn't really loading the other side when said axle is not engaged at the T case, they will not lock on their own.  If the driveshaft is providing loading, they do lock.  However, with a locker up front, I can see enough loading from the outside axle to lock both sides.  When you do lock them in manually, they are just like any other locking hub.
The whole purpose of using these is so you don't have to get out and lock them in if there is only an occasional need.  Drive up to a mud hole, throw the Tcase in 4x4, and drive through.  If you are using them on snow and ice you just need to lock them in.
Finally even found a good pair of 27 spline versions for my 44 axle project.  The only real downside is finding parts these days but I have enough extras now to steal what I may need.  They don't break any easier than the manual Warns.
John, Bozeman, MT
