Author Topic: Leaf Spring Repros  (Read 12278 times)
Re: Leaf Spring Repros
« Reply #15 on: October 18, 2013, 09:54:45 PM »
I bought the Omix Ada springs for the front of mine, drove out the bushing and have been pretty happy with them.  For the back I bought a recurve kit from 4 wheel drive parts.  It's a heavy short spring that fits on the bottom of the spring pack.  I had to pull two springs to get them on.  But it pushes the spring pack back into the right curvature and seems to eliminate the jeep list.  I've been happy with them, nice enough ride and fair enough load capacity.
« Reply #16 on: November 12, 2013, 04:34:04 PM »
I was just flipping back through some rebuild pics and I stumbled across my springs fresh out of the box - turns out they are OMIX-ADA afterall! I bought them from Kaiserwillys but they can be had MUCH cheaper from other sources. I'm running 9 leaf on the rear and 8 on the front. If they have sagged it's been very slight. I have nearly 2 years (1 year actually running) with these springs and nearly 3500 miles. No issues yet.
« Last Edit: November 12, 2013, 04:34:32 PM by Ryan_M »
« Reply #17 on: November 12, 2013, 05:12:04 PM »
I got mine from KW as well - Omix Ada - I had a $25.00 credit at KW and then they had a 10% discount with free freight. Total 4 springs (9 & 10 leaf) around $425
Check out tech talk - they are a bear to install the U shackles on the rear for some reason. Non of mine had the bushings installed. With no weight on the front end the 10 leaf springs feel solid.
Offline johnrb3b
    • Jeeps and stuff
« Reply #18 on: November 14, 2013, 10:43:02 AM »
So all this talk about driving out end bushings and such has me confused.
I bought my springs from Walk's and simply bolted them in place.
Is this another case of KW parts not being quite what they ought to be?
Carl told me his springs were US made.
I've bought several parts from KW and even more from Walk's.
My experience with KW has been that you need to know more than they do which, in my case, isn't that big a problem.
With Carl Walk, on the other hand, he knows WAY more than I'll ever know and he's been dead-on correct every time I've had a question.
KW are nice people and their prices and service are good, but they simply are NOT as knowledgeable as Carl. Put him together with Herm the Overdrive Guy and you may well have all that is possible to be known about old Willys.
« Last Edit: November 14, 2013, 10:47:55 AM by johnrb3b »
« Reply #19 on: November 14, 2013, 10:57:12 AM »
My OMIX springs as purchased from KW were not that difficult to replace. They were one of the first things I did and being ultra-green at this stuff at the time any problem would have been a huge challenge. As far as I remember they just bolted right up.
« Reply #20 on: November 14, 2013, 11:28:48 AM »
I agree 100%...
I put a set of four Walck's spring packs on my CJ-5. They went on fine and work great.
The set of four spring packs on the 3A were from Kaiser-Willys in their "Master rebuilt" suspension kit. Crown automotive springs...really difficult to install the U bolt shackles and pretty stiff.
KW may source their springs from different suppliers depending on where you live. With free shipping offered it's in their interest to find the nearest supplier. Mine came from Reno/Sparks Nevada, about 400 miles away...
