Author Topic: Fuel problems  (Read 7551 times)
Offline tomcattoy
Re: Fuel problems
« Reply #15 on: June 26, 2013, 11:04:08 PM »
I did not use a spacer at the fuel pump.  I like the idea of the spray bottle with gas...I'll try that this weekend.
The gas I put in is just regular 87 gas, and it is basically clear (white), as can be seen in the photo.  The same gas came out the amber color at the carb connection....very strange.  I will probably drain everything and start again too see if the color change continues.
I will post the results.
Offline tomcattoy
Re: Fuel problems
« Reply #16 on: August 24, 2013, 11:42:24 AM »
Been awhile, but wanted to report that the jeep is now running good.  Turns out it was the wrong coil.  I ended up taking it to a local shop and they determined that it had a coil requiring an external resistor (which I don't have), so installed a coil with internal resistor and it runs fine.
The gas color issue went away, so it may be that the new filter or fuel tank had some coloration that eventually cleared out.
Now I have a noisy 3rd gear to work on and some chatter in the rear end when making a tight turn....oh well.
