Author Topic: Overcharging  (Read 9681 times)
Re: Overcharging
« Reply #15 on: July 19, 2013, 08:31:17 AM »
Thanks! I didn't use the original bracketry though. I made a steel bushing that took the place of the rubber one on the front engine plate and then made a bracket similar to this one on the 3B page. I did this for my '53 also, but in 12v.
You can use the original wire from the voltage regulator that goes to the battery. I had to take a chainsaw file and open the hole up some so it would fit on the alternator terminal.
http://www.film.queensu.ca/cj3b/alternator.html
« Last Edit: July 19, 2013, 08:31:52 AM by garage_gnome »
Re: Overcharging
« Reply #16 on: July 19, 2013, 09:12:11 AM »
What did you use for a belt, Nate? Is it the same width as the stock belt with a wide pulley on the alternator?
Would like to see your bracket if you have a pic of it. If not I get the idea....
Re: Overcharging
« Reply #17 on: July 19, 2013, 10:24:54 AM »
I used a B sized belt. It was what I had.
The bracket isn't too pretty. I wanted to try to make it look like is was cobbled together at a maintence facility for forest service vehicles. It kind of matches the oil filter bracket. The one on my 53 looks much nicer and is of the same design.
Re: Overcharging
« Reply #18 on: July 19, 2013, 10:31:14 AM »
I left the original voltage regulator in place too to make it abandoned in place.
And then here is someone's oil filter bracket. I added the new support rod to it. These types of modifications have that maintence garage look to them.
Re: Overcharging
« Reply #19 on: July 19, 2013, 10:46:33 AM »
That oil filter bracket looks like the same one I have seen many times on plow equipped jeeps where they had to move the oil filter to the fender.
Is a B Belt the same as stock or narrower? I don't know belt sized by letter...
Re: Overcharging
« Reply #20 on: July 19, 2013, 10:49:36 AM »
Narrower. The correct size for the alternator pulley though.
This jeep never had a plow. I think the oil filter was moved for ease of changing the filter.
Offline Birddog7
  • Still Plays With Willys
Re: Overcharging
« Reply #21 on: July 19, 2013, 10:55:55 PM »
Here are pics of my nice clean Alt. instalation.  ;D Super bubba at his best.
Birddog7
1945 CJ2A
1946 CJ2A
1948 CJ2A
1948 CJ3A
1956 CJ3B
Re: Overcharging
« Reply #22 on: July 20, 2013, 10:20:04 AM »
That was a good move Nate. Going to a 6v alternator solved the problem and it will charge at idle now.
Re: Overcharging
« Reply #23 on: July 20, 2013, 11:06:34 AM »
Yeah it was! Last night I was out four wheeling with some friends and the lights were super bright! I was really happy with it.
Re: Overcharging
« Reply #24 on: July 20, 2013, 12:33:10 PM »
6 V lights were super bright?? Sounds too good to be true..
That's right... you are one of them young whippersnappers, that can actually still see, aren't ya... ;D :D ;)
Did you get the alternator from the ebay dude or did you find a better local source?
Re: Overcharging
« Reply #25 on: July 20, 2013, 03:26:15 PM »
I got it from the ebay dude. 8) The lights were far better than before when the generator was functioning properly.
Re: Overcharging
« Reply #26 on: July 24, 2013, 10:35:11 AM »
Just wanted to give an update. The 6 volt alternator is the way to go if you want to stay 6 volt but have better lights. It has been working great and no more stupid generator issues to worry about!
Re: Overcharging
« Reply #27 on: July 28, 2013, 08:45:59 AM »
Nate,
I went to the single wire alternator several years ago, never looked back. I had converted mine to 12 volts in order to be able to use modern accessories like winches and lights, haven't gotten that far yet , but I do like the reliability of the alternator.  And if you have to its pretty easy to convert it back.
Todd
Re: Overcharging
« Reply #28 on: July 28, 2013, 11:33:21 AM »
I did a delco 10si (single wire) 12v alternator swap on my '53 years ago. Love it and I'll never swap that back.
