Author Topic: Gas tank isolator  (Read 3435 times)
Gas tank isolator
« on: November 30, 2012, 07:45:22 PM »
I just noticed my gas tank vibrates in harmony with the low idle on the jeep.  When I installed it I know it's metal to metal.  What are you guys putting between the tank and body of your jeeps?
Todd
Offline Pats4WD
Re: Gas tank isolator
« Reply #1 on: November 30, 2012, 08:26:19 PM »
I used strips of an old worn out tire.  I cut down between the tread and used 4 strips I think.  I did it to leave space for moisture to run out from under the tank and air to circulate.
Proud owner of Grandads 51 CJ3A
Offline Macgraham
« Reply #2 on: November 30, 2012, 08:41:03 PM »
Most parts suppliers have wear strip kits to go under the tanks. You don't want them too thick or the filler neck will not line ip well.  G503, KW etc.
Offline Carls_jeep
« Reply #3 on: November 30, 2012, 09:28:09 PM »
I have some industrial conveyor belting that I cut strips from to put under the tank and strips of inner tube under the top bands.
Offline johnrb3b
    • Jeeps and stuff
« Reply #4 on: December 01, 2012, 11:01:54 AM »
It's great how hobbies can overlap.
We used 2" wide strips of Hypalon left over from a "hull reinforcement kit" from my Folbot kayaks.
You put strips along the outside of the hull where the inner aluminum frame parts meet the hull. Then when you scrape over a rock, the strip takes the damage and is a sacrificial, replaceable part.
I also used up most of a kit repairing my badly damaged, NEW Citibot skin. Hadn't put the sacrificial strips on yet and came close to trashing the hull. Gory details in case anyone is interested. Don't try this at home. �;)
http://home.comcast.net/~jrburch_h/folbot/mymods/citibot_repair/citibot_thrashed.html
Offline Dennisanvil
  • Still Plays With Jeeps / blacksmith/ woodworking
« Reply #5 on: December 01, 2012, 03:03:19 PM »
i use a old mud flap. i ran it thru the table saw.
dennisanvil
Offline turkehunt
« Reply #6 on: December 02, 2012, 04:57:43 PM »
I used some closed cell insulation made for water pipes I got at Lowes Hdw. It has a peel & stick backing so I just cut a piece to the width of my tank then cut it into two pieces length wise - peeled the backing & stuck it on the bottom of my tank !
Offline rocketeer
  • Support Our Troops.
« Reply #7 on: December 02, 2012, 06:53:10 PM »
Check with the parts suppliers, they sell kits. Here's a link to BobW's website with all the info:
http://www.cj3a.info/tech/gastank.html
