My Willys 3A and 3B Community
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
News:
Welcome everyone from the CJ3B!
Willys is a big family.
Home
Help
Search
Downloads
Gallery
Login
Register
3A, 3B, DJ Technical Knowledge Base
"Original"-- Technical Questions, Answers, Observations
Gas tank isolator
« previous
next »
Reply
Print
Pages: [
1
Go Down
Author
Topic: Gas tank isolator (Read 3440 times)
Gunslinger
Flatfender Master
Cj3a, M38A1,
Gas tank isolator
on:
November 30, 2012, 07:45:22 PM »
I just noticed my gas tank vibrates in harmony with the low idle on the jeep. When I installed it I know it's metal to metal. What are you guys putting between the tank and body of your jeeps?
Todd
Logged
Pats4WD
Project Jeep (Newbie)
Still Plays With Jeeps
Re: Gas tank isolator
Reply #1 on:
November 30, 2012, 08:26:19 PM »
I used strips of an old worn out tire. I cut down between the tread and used 4 strips I think. I did it to leave space for moisture to run out from under the tank and air to circulate.
Logged
Proud owner of Grandads 51 CJ3A
Macgraham
Flatfender Enthusiast
Reply #2 on:
November 30, 2012, 08:41:03 PM »
Most parts suppliers have wear strip kits to go under the tanks. You don't want them too thick or the filler neck will not line ip well. G503, KW etc.
Logged
Carls_jeep
Flatfender Master
Reply #3 on:
November 30, 2012, 09:28:09 PM »
I have some industrial conveyor belting that I cut strips from to put under the tank and strips of inner tube under the top bands.
Logged
johnrb3b
SMF Administrator
Flatfender Master
No such thing as too many Jeeps - well maybe
Reply #4 on:
December 01, 2012, 11:01:54 AM »
It's great how hobbies can overlap.
We used 2" wide strips of Hypalon left over from a "hull reinforcement kit" from my Folbot kayaks.
You put strips along the outside of the hull where the inner aluminum frame parts meet the hull. Then when you scrape over a rock, the strip takes the damage and is a sacrificial, replaceable part.
I also used up most of a kit repairing my badly damaged, NEW Citibot skin. Hadn't put the sacrificial strips on yet and came close to trashing the hull. Gory details in case anyone is interested. Don't try this at home. �;)
http://home.comcast.net/~jrburch_h/folbot/mymods/citibot_repair/citibot_thrashed.html
Logged
Dennisanvil
Willys Fan
Still Plays With Jeeps / blacksmith/ woodworking
Reply #5 on:
December 01, 2012, 03:03:19 PM »
i use a old mud flap. i ran it thru the table saw.
dennisanvil
Logged
turkehunt
Reply #6 on:
December 02, 2012, 04:57:43 PM »
I used some closed cell insulation made for water pipes I got at Lowes Hdw. It has a peel & stick backing so I just cut a piece to the width of my tank then cut it into two pieces length wise - peeled the backing & stuck it on the bottom of my tank !
Logged
rocketeer
Flatfender Master
Support Our Troops.
Reply #7 on:
December 02, 2012, 06:53:10 PM »
Check with the parts suppliers, they sell kits. Here's a link to BobW's website with all the info:
http://www.cj3a.info/tech/gastank.html
Logged
http://www.enter.net/~rocketeer/13thaaf/13thmain.html
Reply
Print
Pages: [
1
Go Up
« previous
next »
Gas tank isolator
