Author Topic: CJ-3A wiring  (Read 31308 times)
Offline dodjh
Re: CJ-3A wiring
« Reply #30 on: July 03, 2012, 11:18:31 PM »
Now thats what I'm talking about!  Just don't drive too fast and be safe.
I'll check out Ford Starter Solenoids and the Pinto wiring diagram.
I believe the way you described the function of the I terminal is exactly right!  I could hear some bells ringing in my head.
dodjh
Offline dodjh
Re: CJ-3A wiring
« Reply #31 on: July 04, 2012, 06:16:27 PM »
HAPPY 4TH OF JULY TO EVERYONE!
I was routing the new wiring in my mind and came to a fork in the road, to make sure my gauges light up,
(not sure if they were before or not) do I run a jumper wire from one gauge to the other and then tie them in
with the ignition.  Ummm just thought of something.....I don't want them to light up unless my head or running lights are on.
So to answer my own question, I need to tie them in with my independent head and tail light system and run a jumper from one to the other for them to have juice...right?
Offline NoCoWillys
Re: CJ-3A wiring
« Reply #32 on: July 04, 2012, 08:02:24 PM »
Your dash light, or the lights in aftermarket gauges should be wired in off the light switch.
'53 CJ3a
Offline dodjh
Re: CJ-3A wiring
« Reply #33 on: July 04, 2012, 08:37:22 PM »
I'm going to try and use the same gauges (don't know if they're orginal or A.M) which look old.
If they are 6 volt gauges, will I need to change them?
Offline NoCoWillys
Re: CJ-3A wiring
« Reply #34 on: July 04, 2012, 11:03:14 PM »
I'm sure the oil and temperature gauges would be fine since they are mechanical.  If yours aren't, then it may take a little more digging.  I think the ammeter would be OK, maybe someone else here could chime in on that part.  If you are now doing the conversion to 12 volt then your will likely need to change out your fuel gauge.
'53 CJ3a
Offline dodjh
Re: CJ-3A wiring
« Reply #35 on: July 04, 2012, 11:25:53 PM »
NoCoWillys.... it was converted to 12 Volt by a previous owner.  My oil and Temp are already mechanical.
I have to figure out the gauges of the wiring to all the components.
There is a link I read about that...it may have been on the CJ2A.
Thanks for your input.
Offline dodjh
Re: CJ-3A wiring
« Reply #36 on: July 09, 2012, 11:36:36 AM »
HI...had a question about ballast resistors...mine has the thermal type (wires esposed) but their is a non
thermal type (wires concealed.)  They have different ohms reading for checking them but which one should
be used on the CJ3A?
Thanks
Re: CJ-3A wiring
« Reply #37 on: July 09, 2012, 09:46:58 PM »
You need to use the ballast resistor that matches the ignition coil. What is the original application for the ignition coil?
I'd just use an early CJ-5 12V coil so no ballast resistor is necessary.
Offline dodjh
Re: CJ-3A wiring
« Reply #38 on: July 09, 2012, 11:59:03 PM »
Bob W....so the wire that would go from ignition switch to ceramic ballast resistor would go straight to
the +engine coil?
Offline dodjh
Re: CJ-3A wiring
« Reply #39 on: July 10, 2012, 12:18:44 AM »
I need to specify that I wil continually need help while doing this phase of the restoration.
There are a lot of old bareless wires that have to be run down and determine if they are necessary.
I wish some one had a wiring diagram of a CJ3A with a 6 Volt starter and a 12 Volt battery with
wires going to Battery, starter solenoid, alternator, ammeter, push start switch, coil, fuel tank and distributor.
Not to forget the ceramic ballist resistor in thermal or non thermal mode. Things work out better for me when
I can see what the finished picture looks like.
I still don't know why the starter solenoid has to be shorted sccross the + side lug and the S terminal.
Any additional help will be greatly appreciated.
Re: CJ-3A wiring
« Reply #40 on: July 10, 2012, 05:50:20 AM »
the +engine coil?
Yes, that is how it would be hooked up.
Offline dodjh
Re: CJ-3A wiring
« Reply #41 on: July 11, 2012, 06:10:48 PM »
I'm still at it and run into stalls due to my lack of knowledge.
How can I tell if my gauges are 6 or 12 volt?
I don't know what the previous owners did to this CJ....but I do know it has a 12 Volt B., a Ceramic Ballast resistor, 12 V coil, alternator and points, rotor cap,  Distributor and JC 8C plugs.
If the gauges are orginal, will they light up?
Thanks for any help,
Re: CJ-3A wiring
« Reply #42 on: July 11, 2012, 06:40:13 PM »
I don't believe original gages had any bulbs in them to light up.. If you look at the backsides usually the voltage is marked on replacement gages....and if there are bulbs, check them for markings too. Replacement gages are cheap, might just want to put new ones in..
Is there any thing underdash that looks like a drop down resistor to lower the voltage the instruments run on? Otherwise for a 12 volt system you will need a 12 volt Fuel gage and sender EDIT, I see kaiser willys senders work on both 6 and 12 volt so maybe you do not need a 12 volt sender??).. I think the 12 V ammeter and 6 V ammeter are the same but I could be wrong....and the temp and Oil gages were mechanical originally..
« Last Edit: July 11, 2012, 06:45:32 PM by F_Bill »
Offline dodjh
Re: CJ-3A wiring
« Reply #43 on: July 11, 2012, 07:15:07 PM »
I remember reading, you could use a 6 or 12 volt fuel gauge. �I'll have to look real close under the dash....it has been raining off and on for the last week here and I haven't been able to get much done.
I was just checking out the earlier site that you mentioned at the beginning of "Tech Talk," it would only go back 1,000 posts which was around 2010.
Are you still on the road or shut down for awhile?
Re: CJ-3A wiring
« Reply #44 on: July 11, 2012, 09:21:28 PM »
Photos of what you have on your Jeep would help us help you.
