Author Topic: Tub Repairs----Progress (Photos)  (Read 8031 times)
Re: Tub Repairs----Progress (Photos)
« Reply #15 on: October 26, 2011, 08:17:01 PM »
Hey Bretto,
The hat channel that crosses directly below the gas tank has a threaded insert.  The bolt is screwed up through the out rigger body mount and into the hat channel.  This is the only mounting location that is done this way.
I am no pro, but probably a couple reasons for it. 1. A through bolt with a hex head under the gas tank is probably not desireable.  It could rub and eventually cause a leak. 2. If you want or need to remove or lift the tub, you don't need to pull the gas tank to do it.
