Author Topic: Vaccum powered Wipers  (Read 9472 times)
Re: Vaccum powered Wipers
« Reply #15 on: April 20, 2011, 09:20:32 PM »
If the engine front plate bends to the rear on the driver's side the vacuum booster pump probably won't fit. Sounds like you are describing the adapter pictured below in the photo from The CJ3A Page. This adapter allowed for using a CJ-3A frame as a service replacement for a CJ-2A frame after the 2A frames had been discontinued. Essentially the adapter enabled a CJ-2A engine with symmetrical mounts to fit a CJ-3A frame with offset mounts.
« Reply #16 on: April 20, 2011, 10:07:02 PM »
Bob, You are exactly right. I think I figured out how to post photos, but you beat me to the punch.
Here is a photo anyway. �Just when I think I've run into something new, guys like Bob and Larry show me otherwise. �Someday I hope I'm not such a newbie.
That motor mount looks bad to me. �Fan occasionally makes contact with lower part of radiator shroud What do you think?
Thanks again.
« Last Edit: October 06, 2017, 08:59:25 PM by athawk11 »
« Reply #17 on: April 21, 2011, 07:50:36 AM »
Yep, that's what they did, use the adaptor to adapt an early engine plate to a later frame. The easiest way to correct that would be to replace the front engine plate with a CJ3A plate.
