Author Topic: Rear Axle  (Read 7890 times)
Re: Rear Axle
« Reply #15 on: March 16, 2011, 07:55:10 PM »
I haven't personally pulled an axle bearing of these jeeps but, once the brakes and retainer are removed, can't you just pull on the axle and it will come out? �Bearings and all? ��
Yes, just grab ahold of the axle and pull and it will come out.
However, at this point, if the roller cage is busted the axles will have to be taken to a machine or auto shop to have the old ones pressed off the shaft and have the new ones pressed on. The damage is done.
I would suggest getting a manual. Do not attempt to reinstall the axles until you have read up on, and understand how to properly shim the retainers. Too tight and the bearings will burn, too loose and they will break.
