Author Topic: starter rebuild  (Read 10251 times)
Re: starter rebuild
« Reply #15 on: January 14, 2011, 04:50:03 PM »
It could be a bad battery. The battery may not pass a load test.
Very possible. I've seen it before.
Here's a little test. With the ignition off, remove the hot cable from the battery and see if there is any spark. Connect a voltmeter between the cable and the battery post and see if you get any reading. You might have a draw on the battery with the ignition off that is draining it down.
Re: starter rebuild
« Reply #16 on: January 14, 2011, 11:33:58 PM »
Yep, the alternator can have a bad diode that will drain the battery. I had that happen on my Jeep.
Offline danorte
Re: starter rebuild
« Reply #17 on: January 19, 2011, 02:33:37 PM »
Thank you all, will recheck this weekend to see if load, drain or other abnormalities. North
