Author Topic: Dual carbs  (Read 45207 times)
Offline beefspots
Re: Dual carbs
« Reply #45 on: July 17, 2013, 12:08:36 PM »
Sweet Mod Nate
Offline Haines Garage
  • Bubba! I got the Chain Drive!!
Re: Dual carbs
« Reply #46 on: August 11, 2013, 06:16:07 PM »
This is one of the coolest projects I've seen here. Can't wait for the test run video.
Me two...No pun intended ;)
Getting there is not half the fun, getting there is All the Fun!....Am I there yet?
Offline stony
Re: Dual carbs
« Reply #47 on: August 17, 2014, 12:15:14 PM »
Nate:  what did you use for your flanges on the block?  Just got my block apart and may want to fool around a little with dual carbs, have 2 WO's (I think).  Thanks!
Terry
Re: Dual carbs
« Reply #48 on: August 18, 2014, 05:22:00 AM »
Traced the gaskets on a piece of steel and cut with a plasma cutter.
Offline Mark W.
  • Chug A Lug
Re: Dual carbs
« Reply #49 on: January 06, 2015, 12:38:57 PM »
Would be interesting to find a way to compare your dual carb setup to the Weber 32/36 progressive 2 barrel I am planning. I'll be using an aluminum manifold made from 2) aluminum pipe elbows and an aluminum box milled out of a small block of aluminum. I am also building a header for the engine and will have the header flange (going to be 3/8" T) pass over the intake ports and the Intake manifold will bolt to it to make it easy for the two different metals to expand. Instead of trying to use one bolt to hold two different metals.  I'll be running a fresh air intake system that will put the Air cleaner ahead of the raditator just below the hood. I'm working on some sort of high water baffle or possibly a way to reroute the air intake for deep water.
I love how clean and simple your dual carb setup is. VERY Hot Roddy
Chug A Lug
1948 CJ2A Tub and Title
1949 CJ3A Windshield
1957 CJ5 Frame and Springs
DIY Aluminum Hard top
Offline Ryan_289
Re: Dual carbs
« Reply #50 on: March 05, 2015, 05:00:44 PM »
I like it!  It looks pretty stock too.
Offline Steve R
Re: Dual carbs
« Reply #51 on: March 31, 2017, 04:32:38 PM »
It is two year later. Does it still work? Have you made more? Will you make more? Am sure there are a lot of us who want some additional power but don't want to butcher their Willys.
Re: Dual carbs
« Reply #52 on: November 20, 2017, 06:05:03 AM »
I gave up on the dual WO's. I could not make Ted run right on them. The dual YFs on Red jeep work great still.
Offline Steve R
Re: Dual carbs
« Reply #53 on: November 20, 2017, 05:48:32 PM »
Lost something. As I was trying to say, I am sure there are a lot of us who do not want to replace their go devil engines but want some more power. What do you recommend?
Re: Dual carbs
« Reply #54 on: November 21, 2017, 06:04:51 AM »
On my red '53, I put  supersonic head and dual YF carbs from an F head. That makes awesome power and have no complaints.
On my '49 3A, Ted, I put dual WOs after rebuilding the engine. I could not get that one to run right. I made new jets and converted the oil bath air cleaner to a paper one. I went back to one and put the oil bath back together. I wanted to use WOs because of how they can be cleaned on the trail.
Offline mtnman37879
  • Plays With Jeeps
Re: Dual carbs
« Reply #55 on: November 21, 2017, 05:04:47 PM »
Henry J's had the same engine with the Super Sonic head and they had a 2bbl carb on a manifold designed for the 2bbl carb.
