Author Topic: Wobbly pedal fix....from Willys via Bob W.  (Read 10322 times)
« on: April 18, 2013, 10:00:03 AM »
http://www.cj3a.info/tech/pedalslack.html
Check it out ....a fairly simple fix if you can do some lathe work.
Re: Wobbly pedal fix....from Willys via Bob W.
« Reply #1 on: April 18, 2013, 12:00:34 PM »
None of mine have slop, but that is something I'll keep in mind!
Offline Mark W.
  • Chug A Lug
« Reply #2 on: January 07, 2015, 01:44:36 AM »
I have one of these. Dad must have put it on Chug in the 60's when he was driving it every day to work. I'm completely rebuilding the whole clutch linkage with new parts or with redesigned parts so I doubt I will need it. But I'm going to clean it all up and keep it in case someday. I also have the original instruction sheet for it. It was in my repair manual.
Chug A Lug
1948 CJ2A Tub and Title
1949 CJ3A Windshield
1957 CJ5 Frame and Springs
DIY Aluminum Hard top
« Reply #3 on: January 07, 2015, 11:51:12 AM »
Thanks, Bill.  I'm kind of surprised that nobody is making these.  Maybe another idea for the Tightsteer guys.
Offline Mark W.
  • Chug A Lug
« Reply #4 on: February 03, 2015, 04:55:55 AM »
I ended up using mine as part of a very modified Pedal shaft set up I built I posted a long photo heavy post in my Chug A Lug project thread on the 2A forum.
I guess I can see if I can cut and paste it here to.
So I been up to my Bee Hind in finishing up the fancy Clutch/Brake pedal arm to the Clutch Pedal Shaft and the mount to the frame. I'm pretty happy with the way it all can out.
So here it is my new upgraded and modified factory Clutch and Brake shaft assembly.
A little closer view of the assembly. This uses the Willys Factory Pedal Slop fix kit (thats the long bolt running through the center of the assembly and the cupped washer and the hollow adjustment nut followed by the Nylon insert Jam/locking nut) I have done away with the cotter pins and the steel washers. All wear surfaces and pivot points are Bronze Oilite Bearings. And all are serviced by a Gease Zerk.
Just a view from the other side
Bottom view ? Well actually this will be the view from the top when installed. The Mount attaches with 4) G8 5/16"-18T bolts cut to fit the application. You can see the spacer I made from a 7/8" ID x 1 1/2" OD shaft collar. It was just easier to start from the Collar then to make one from scratch on the lathe. But it worked out real well allowing me to lock the collar to the shaft and keeping it from rotating and causing wear. I ended up changing the plate shown with the 4 bolts in it. When I built the Master Cylinder mount I put in.
http://i65.photobucket.com/albums/h217/UJ78/Willys%20project/Clutch%20and%20Brake%20shaft%20assembled%20web%204_zpsw8ba59kc.jpg
The space you see to the right of the Brake Pedal arm is where the brace will attach between the shaft assembly and the master cylinder mount. I'm going to be making this from 1/4" T stock and I bought some 10-32T tiny grease zerks so it can be serviced.
OK here is everything laid out.
From the left
3/8"-16T Nylon insert Lock nut
Cupped threaded adjustment Nut for the Willys Pedal Slop Fix Kit
.125"T X 1.00" ID X 1.50" OD Thrust Bearing
.250" W X 1.00" ID X 1.125" OD Bronze Bushing
.065"T X 1.00" ID X 1.50" OD Thrust Bearing
Brake Pedal Arm with 1.00" ID X 1.25" OD Bronze Bearing Pressed into the Arm. Then faced off.
Special Shaft collar made with a set cut inside to allow room for weld line on Clutch Lever
Next would come the Clutch Lever mounted on the Clutch Shaft (show in the above line)
Clutch Shaft Assembly to Frame mount
Bronze 1" ID x 1 1/4" OD w/ 1/8" T x 1 1/2" Flange OD
Tube made from 1.5" x 2.75" 1020 Cold Rolled shaft material Bored to an ID of 1.250" Bronze bushings were then Pressed in place. Once assembled the ends of the Tube were faced off square with the Bore.
Once the Tube was assembled and the base of the Mount was roughed out. I took to press the Tube Assembly into the Mount. I guessed as to exactly what the interference fit would be (could have taken a .001 to .002" off the tube and been safe). I placed the Tube in the Freezer. Once it was as cold as it was going to get I put everything in my large bench vise and started pushing the Tube into place. I got about 3/8" in of the 2" it needed to travel to end up centered.
then out came the propane torch and more reefing on the vise. And it got to the point I was tightening the vise ASAP and then wacking the vise with a hammer to shock it into moving. Much like you would break free a gear puller. This got me to about 5/8" from done. When the Vise came off the bench (not to worry it did that once before about 15 years ago) So I resigned myself to have to take it up to the shop at work tomorrow and press it in with the big Hydraulic press..
Wife screams for dinner/Eat dinner
Great Idea. I assemble a reverse gear puller using some of the parts from my Milling machine hold down set. And with it sitting in the vise (now clamped to the bench) and using 2" 18" box end wenches I managed to get it almost perfect. BUT WHAT A PITA. I need a small press.
OK I have run into some kind of post size limit so this will be continued in the next post
Chug A Lug
Offline Mark W.
  • Chug A Lug
« Reply #5 on: February 03, 2015, 04:58:36 AM »
Some detail on the Mount section showing one of the Bronze bushings and a piece of the shaft material. The actual base is made from a piece of 1.5" x 2" x 4" 1020 Cold rolled Steel I had.
Details showing the protected grease zerk and the backing plate that will go inside the frame. The backing plate which will get welded to the frame.
OK back to the progression down the assembly.
Clutch Pedal Arm
Following seen on the upper line.
Cupped Steel Washer from Willys Factory Slop Fix Kit
Steel 3/8" ID washer
3/8"-16T X 8" bolt with the head slightly thinned.
Attached to the Clutch Lever is one of the two Rod ends that will make up the Clutch Push Rod.
There you have it 4+ days of work I enjoy over engineering things.
Next thing like this is the Master cylinder Mount and then the Steering Box mount (525 Manual Saginaw Box)
Chug A Lug
Offline johnnybravo
« Reply #6 on: August 31, 2016, 08:44:48 PM »
M38 has a nice bolt on assembly.  Readily available, not to pricy and makes easier to drop complete pedal shaft assembly for repair.  You must cut off your OEM original to install.
