Author Topic: The Superior CJ-3A trait  (Read 21949 times)
Re: The Superior CJ-3A trait
« Reply #15 on: November 09, 2014, 04:39:39 PM »
I really don't feel that the stock 3A body can be beat.
You have convinced me, the CJ-3A is the best.� :)
Should we further address stock bodies vs modified bodies ?
Yes.
« Reply #16 on: November 09, 2014, 11:34:06 PM »
OLDTIME wrote....CJ-3A body vs M38 body .........
Concerning floor pans I don't see any big advantage to the removable transmission panels unless the drivetrain is extensively modified requiring custom shaped floor pans.
As for the M38 tailgate mounted spare I feel that it's a superior location to the 3A side mount but inferior to a well designed swing out carrier.
The military dash panel glove box is nice but it interferes with heater installations.
I'd certainly choose a heater over a glove box.
Yeah getting to the gauges can be a real pain on the 3A but normally it rarely needs to be serviced.
I kinda like the park brake cane handle on the left side like the M38, but at least the 3A version is well angled to accomidate right hand use.
May I offer some alternative views on the 3A vs M38 comparison?
I wish Bretto or Ryan would chime in on the removable floor pan.� They have M38s.� Bretto has removed his transmission and TC for a number of reasons.� On one occasion, he just wanted to install a sealed bearing on the front of his tranny to shore up a small leak.� The removable floor makes this a snap.� �Honestly, how many of us 3A owners would go through the trouble of pulling a drive train to stop a small leak?� I contest that most of us would if it were easier to get to the darn thing.
I agree that it's a great advancement, but I feel we should leave a swinging tire mount out of the comparison between the 3A and M38.� After all, it was not an option for either.
Heater vs. Glove box...If we really want a heater in an M38,� we could borrow the original 2A design which was mounted on the driver side.� We could have the best of both worlds.
Removable gauge panel...I found it very challenging to wire my 3A.� Remove seats, add some padding, climb in, and get comfortable.� You're going to be here for a while.� I'm not a big guy.� I can't imagine how difficult this might be for a big or tall fellow.� I know it would have cost a few dollars more to have a removable panel in a 3A, but I think it would have been worth it.
I have no good reason to question the park brake position.� Either right or left of the steering wheel works for me.
Don't get me wrong, I'm a proud owner of two 3As.� I can't help but love everything about them.� But I have to admit, the M38 has a few perks.  ;)
« Reply #17 on: November 10, 2014, 05:56:36 AM »
If we really want a heater in an M38,  we could borrow the original 2A design which was mounted on the driver side.
M-38s had optional heaters. I've never been in an M-38 with a heater but I will bet that it gets HOT, unlike some of the CJ heaters.
« Reply #18 on: November 10, 2014, 08:22:40 AM »
It's night and day. I have removed and reinstalled a transmission/TC in my M38. The removable floor pans make it a relatively painless task. From being able to support the transmission from above to having easy access and visibility when inserting the input shaft into the back of the motor and bolting everything back up - it's a breeze. After completing the process on an M38 I dread having to attempt the same job on my 3A. And my 3A is a candidate for it since the transmission is leaking from pretty much everywhere.
Honestly, I'm surprised it took Willys so long to come up with this. You'd think after an early engineer had to change out his first transmission he would have broken out the reciprocating saw and immediately implemented a design change to all tubs.
« Reply #19 on: November 10, 2014, 07:37:04 PM »
Laugh out loud!� ;D
« Reply #20 on: November 10, 2014, 09:17:04 PM »
Yes I agree it's a real chore lowering a 60 pound transmission that's bolted to a 70 pound transfer case down onto your chest.
That's why we plan ahead. Do it once and do it right.
So I must agree those are valid arguments in favor of the M38 removable floor pans.
That aside I use my jeeps for civilian functions and therefore I prefer CJ designation.
Guided by the topic title....  I believe we have found the CJ-3A to best fill the role of being the lightest universal type jeep ever put into mass production.
And for that single achievement it should be recognized as supreme.
Any more comments on that ?
« Reply #21 on: November 11, 2014, 10:25:51 AM »
...it should be recognized as supreme.
I agree! [smiley=thumbsup.gif]
« Reply #22 on: November 11, 2014, 01:06:31 PM »
We have previously identified the CJ-3A as the lightest mass production universal jeep.
The CJ-3A's low hood and windshield design also provides for superior foreword visibility as compared to other the Jeeps.
It thereby becomes the optimum candidate for certain universal jeep builds.
I� state "certain builds"; because intended useage may dictate other priorities beyond lightness and visibility.
Example:
In my area we have lots of forested trails with mud, rocks and creeks to ford.
So here in the Ozarks the short lightweight jeep with high visability certainly reigns supreme.
In other open areas of the country like Moab; a longer wheel based universal may prove to be the superior off-road performer.
Every operator of the universal jeep should consider using the model and vintage of jeep that best suites their particular needs without need for modification.
For more extensive reading on Jeep modifications see: http://z4.invisionfree.com/CJ3B_Bulletin_Board/ar/t2591.htm
Stock 3A Bodies vs. Modified and Aftermarket 3A Bodies
In general; modifications may be implemented to correct a design flaw.
Modifications are also implemented so as to compliment an already existing trait.
So what all� design flaws do we see in the CJ-3A body ?
And what features can we reasonably or practically hope to correct or to compliment ?
After all, the jeep universal should always be envisioned as a complete and synchronous system.
The "complete synchronous system" directly implies that all individual components and assemblies should compliment one another.
« Reply #23 on: November 11, 2014, 09:08:15 PM »
Besides being prone to rust?
But, really, we have mostly covered the shortcomings...
Poorly place spare tire, lack of a glovebox, no removable floor panel as in the M-38 and CJ-5's..etc...
how about the lack of an adjustable drivers seat....?
« Last Edit: November 11, 2014, 09:48:35 PM by 1955CJ-5 »
« Reply #24 on: November 12, 2014, 12:21:42 PM »
1955CJ-5,
A couple of good points.
The CJ-3B seats were not adjustable prior to 1961.
With minor changes one could easily install the late 3B seats into a 3A.
Willys Motors called them "bucket type" seats.
The 3A and the identical early 3B seats with the steel backs were called "1/3 type" seats.
Yes I suppose that rust is the obvious flaw that we nearly overlooked.
The solution ???
Did you hear in the recent news about Fords big gamble for the F-150 pickup series ?
All 2015 Ford F150's are scheduled to have aluminum bodies .
So what if we put an aluminum body on the CJ-3A ?
Will the aluminum be any more resistant to corrosion than steel ?
We will soon see as the new aluminum Fords will soon be on the road.
And would not an aluminum construction compliment the superior "light weight trait" of the CJ-3A body ?
Maybe and maybe not !
The Aquala aluminum bodies are rather thick. See: http://www.aqualu.com/jeep-bodies.html
« Reply #25 on: November 12, 2014, 12:30:24 PM »
The solution ???
Was it Tumbleweed that had his tub "dipped" and plated? That sounds like a great solution, though it's not available everywhere....
« Reply #26 on: November 12, 2014, 04:47:26 PM »
There is always fiberglass. I built a fiberglass bodied CJ-3A many years ago. The body did not rust, but everything else did (here in the rust belt). The military was experimenting with a "plastic" M-38. I'm assuming that was fiberglass. Still searching for more info about it.
« Last Edit: November 16, 2014, 05:28:10 PM by Bob_W »
« Reply #27 on: November 16, 2014, 08:41:39 AM »
Wow, this is an incredible thread.� I'm thinking we need to archive most of it in an article.
Oldtime said:
:So I ask you all what is it that the CJ-3A continues to excel at that no other Universal model can claim ?"
I haven't a clue what Oldtime� is referring to, but I do have a question for Bob W...What in the M 38 made it so much heavier?� I know about reinforced tailgate, different top, removeable pan, etc...but it seems I must be missing something heavy.
Only thing I can think of is the ability to drop in a later engine in these with the different motor mount design, but that can't be it as you still need to do hood modifications or get the short carb.� To me Universal seems to refer to the anyone can drive it for any purpose....and there were a whole lot of accessories by the time the 3A came around but they all would work on a 2A...
I know...the 3A body tub could be used for the fastest flatfender jeep in production, the king of the hill (paved, of course.. ;D) Dispatcher! :D
« Last Edit: November 16, 2014, 08:48:19 AM by F_Bill »
« Reply #28 on: November 16, 2014, 10:16:16 AM »
"Original 3A body compared to modifications for improvement"
I think a good place to start would be the advancements that have happened to the modern Jeep.
Better paint finishes and undercoating.
And it�s hard to argue with the design change to the fender.� Even the soldiers of WWII knew the flat fender was flawed�
Don�t beat up on me.� I like the look of the flat fender as much as the next guy.� Just trying to stay within the context of this discussion.
« Reply #29 on: November 16, 2014, 05:26:18 PM »
What in the M 38 made it so much heavier?  I know about reinforced tailgate, different top, removeable pan, etc...but it seems I must be missing something heavy.
There is no one item that was really heavy, but everything adds up. It doesn't take much weight to make a huge difference in performance when we only have 60HP on a good day. The electrical system alone added a lot of weight. The military was trying to develop vehicles with interchangeable components to ease parts supply. Just pick up a military tail light and compare it to the civilian type. A Patton tank used the same tail light. How about the voltage regulator. It was so heavy it had to be mounted to the frame. The list goes on and on. During testing the M-38 was considered underpowered compared to the MB, the only thing that made it squeak by was going with 5.38 axle ratio. Add 12HP with the F-head engine (M-38A1) and then things were acceptable.
