Author Topic: Dana 41 Hub Reassembly  (Read 3872 times)
Offline LKap
  • Jeep Fanatic
« on: January 09, 2017, 05:01:57 PM »
I am in the middle of rebuilding my rear hubs.  I have the new inner oil seals and bearings in and packed with grease.  Shims, bearing retainer and backing plate installed as well.  All that is left is the gasket - outer seal - gasket - cover.  Do I need to use any kind of sealant between the gaskets? Dry? Permatex?
Thanks
Re: Dana 41 Hub Reassembly
« Reply #1 on: January 09, 2017, 10:07:49 PM »
You are probably fine if you install them dry.  That said, I coat all surfaces with a very thin layer of Permatex 2.
Hawk
Offline LKap
  • Jeep Fanatic
« Reply #2 on: January 09, 2017, 10:23:55 PM »
Permatex sounds like a good idea.  After all this work I don't wanna pull it all apart if there's grease all over the brakes.
« Reply #3 on: January 10, 2017, 08:34:32 AM »
Don't worry about it Lige.  It just stops all the squeaks.  ;D
Offline LKap
  • Jeep Fanatic
« Reply #4 on: January 10, 2017, 08:47:17 PM »
Mine wasn't that bad! I would post pics but I don't have a photobucket account. Is there any other way to attach pics?
Offline LKap
  • Jeep Fanatic
« Reply #5 on: January 10, 2017, 08:49:23 PM »
Figured it out but the pics are all goofy :D.  Sorry - I'm new at this.
« Reply #6 on: January 10, 2017, 10:15:33 PM »
You can attach as many pictures as you want by clicking the arrow beside the attachment down below. Then you choose your file. Voil�!
