Author Topic: Radiator fixing  (Read 4442 times)
Offline Guy
Radiator fixing
« on: February 24, 2017, 05:36:42 AM »
I'm looking for pictures of an engine bay on how the radiator is fixed in a factory fresh configuration, as a CJ3A came of the factory line.
Reason for asking is that currently a much larger (longer) diesel engine in my jeep resulted in moving the radiator about 2 inches forward on new welded brackets on the tube frame.
As I'm restoring the jeep to its factory condition so the diesel has to go but I'm not sure how to place the radiator back again.
Thx
Guy
CJ3A 1952, former Belgian army.
Former: Willys MB 1944, Dodge WC 52 1943.
Re: Radiator fixing
« Reply #1 on: February 24, 2017, 09:59:01 AM »
A regular production 1952 CJ-3A used a side mount radiator that was bolted to the grill. A Belgian army CJ-3A probably had a bottom mount heavy duty radiator. This would have been mounted the same as on CJ-2As and early CJ-3As.
Re: Radiator fixing
« Reply #2 on: February 24, 2017, 12:32:40 PM »
As many pictures as I take, I couldn't find a very good one of the bottom mount style.
This is a photo of the front tube that I needed to repair.� You can see the heavy duty offset tabs used to mount the radiator.�
You can just see the tabs on the back side of the tube in this photo...
« Last Edit: February 24, 2017, 12:33:43 PM by athawk11 »
Offline Guy
Re: Radiator fixing
« Reply #3 on: February 25, 2017, 05:32:26 AM »
Okay, thanks for the reply. It explains a lot.
Seems these tabs have been removed on mine, unfortunately
The upward welded piece was the new attached for the radiator. This piece blocks the correct installation of the grill.
Guy
« Last Edit: February 25, 2017, 05:34:27 AM by 712ROB »
