Author Topic: Gas tanks  (Read 14056 times)
Offline Mark W.
  • Chug A Lug
Re: Gas tanks
« Reply #15 on: December 24, 2014, 12:31:18 PM »
For a cheap way to "shake" gravel or chain in a fuel tank. Use a small cement mixer. I made a couple L shaped brackets that are attached to the front edge of the drum on my little 3 cu ft mixer I got from one of the Home stores. I then placed a couple pieces of old heavy material like Blue jeans around the opening of the drum. Placed the Tank against this and using heavy bungie cords attached the tank to the drum. I put about a shovel full of crushed 3/8" open rock (no fines all rock is about 3/8") if you can't find this easy to make some from 3/4 minus just screen the rock with a 3/8" mess screen for the first step then do it again with a 1/2" screen you will end up with rock all about 3/8" with sharp edges.
Turn the mixer on and let it run for a hour. (remember to lube the mixer. I then turn the tank 90 degrees and let it run another hour.
Came out looking almost sand blasted but shinier.
Chug A Lug
1948 CJ2A Tub and Title
1949 CJ3A Windshield
1957 CJ5 Frame and Springs
DIY Aluminum Hard top
Offline BMIC
  • Weekend Mechanic
Re: Gas tanks
« Reply #16 on: December 24, 2014, 12:48:32 PM »
Neat trick Mark, are you going to seal or coat the tank now?
Offline Mark W.
  • Chug A Lug
Re: Gas tanks
« Reply #17 on: December 26, 2014, 11:31:31 AM »
Nope replacing the tank the process showed where the tank was to damaged to be reused. Once some of the rust was removed it was clear parts of the tank were very very thin.
My younger brother also uses a variation of this method to clean Harley tanks at his bike custom shop. There he is cleaning smaller tanks so he opened up the mouth of the drum and removed the paddles inside. he then uses dense foam blocks to hold the tank in place inside the drum. It is my understanding he does coat the inside of the tank once cleaned.
Chug A Lug
