Author Topic: DIY Modern starter  (Read 10818 times)
Robert U'Ren
  • Guest
Re: DIY Modern starter
« Reply #15 on: March 15, 2022, 05:45:54 AM »
I wondered if anyone could give me the model or number of the toyota 4.2 starter shown in the picture with an air compressor beside it fitted on a grey engine , my tel number is 01548521278 I sell willys mb and cj2 jeeps with the standard small clutch and wondered if this starter would be ok for any 12 volt conversions i do, Im not a fan of the reduction gear type as they are noisy but i like the look of that one in the picture, direct drive
Robert U'Ren
  • Guest
« Reply #16 on: March 15, 2022, 10:10:04 AM »
would anyone be able to tell me the serial number of the toyota 4.2L direct drive starter seen fitted to the gray engine , I wondered if it would fit a ww2 or Hotchkiss m201 engine , they have 10 tooth starters that are 1.5 inch diameter, I can cut the nose cone off lengthen the holes, reduce the diameter of the end of the spindle by putting it going in a vice and holding a grinder to the end until diameter is right , greatly hoping someone can help with this as so many people out there are using the 6 volt crash bang inertia starters with 12 volt battery's and mashing up their ring gear
It would be great to help so many people get a reasonably priced 12 volt pre engaged direct drive starter and all these 12 volt converted jeeps would sound so much more refined on start up
i can be emailed on reusablematerial@btconnect.com
Offline Mark W.
  • Chug A Lug
« Reply #17 on: March 17, 2022, 11:41:41 PM »
I don't have a part number for the starter I used and iif I did it would be from the rebuilders. Its not an original part. Its re manufactured. But the application is for a Toyota Landcruiser with a 4.2L in line 6 cylinder. Mid 1960's ear I believe.
Chug A Lug
1948 CJ2A Tub and Title
1949 CJ3A Windshield
1957 CJ5 Frame and Springs
DIY Aluminum Hard top
