Author Topic: replacement tubs  (Read 2728 times)
Offline MikeP
replacement tubs
« on: July 14, 2019, 09:59:27 PM »
this may not be the right place for this so if it needs to be moved please do so
so im curious were is the best place and price to buy a new tub for a 3a ive seen them as low as 2 grand on ebay and the brand name says md juan? and i know there is omix ada and then what else is there money isnt exactly tight but takes time to save but what ever pennies i can pinch for the best quality i can get ill do it
1950 willys cj3a
Online Rus Curtis
Re: replacement tubs
« Reply #1 on: July 15, 2019, 08:47:24 AM »
Mike,
This topic alone is enough for a book.  There is a lot of published information on replacement tubs.  My understanding is MDJuan is the only manufacturer.  Everybody else is a distributor.
There is a long thread on updates to fix problems that have plagued MDJuan's production for decades.  Rommel came to a Reunion a few years back and over the course of several months a lot of feedback was provided.  Things were fixed.
The tubs are better now but still not perfect.  Apparently Rommel has focused his attention in another area.  I'm not sure.
To ensure you get the latest and best available, you will need to be able to decipher the manufacture date, i.e. before the updates (more manipulation will be needed) or after the updates (fewer modifications to get it to fit).
Willys Overland in Toledo has made a business out of "fixing" the tubs so they fit.  I haven't kept up with them much.
There are multiple vendors that supply the tubs.  There was even a military vendor that was doing his best to ensure his tub kits were the latest so they should be on your shopping radar.
Some of the posts:
https://www.thecj2apage.com/forums/new-tub_topic44082_post440449.html?KW=mdjuan#440449
http://www.cj3apage.com/cgi-bin/3Ayabb26/YaBB.pl?num=1480176972/2#2
https://www.tapatalk.com/groups/cj3b_bulletin_board/viewtopic.php?f=2&t=3697&p=36020&hilit=mdjuan#p36020
Offline MikeP
« Reply #2 on: July 15, 2019, 09:32:48 AM »
after reading posts and other reviews of the tubs this place seems to be the best as i dont have to do all the work that they are doing for me however im not sure on prices i guess ill need to call them and hope it dont cost alot more than i want
https://www.willysoverland.com/
1950 willys cj3a
Offline MikeP
« Reply #3 on: July 15, 2019, 10:36:19 AM »
can the cowl/firewall of a cj3a fit with the back half plus tool box of an m38 tub using the repair floor pans of a cj3a a link to a m38 tub with my idea and the reason i say my cowl is because i still want to use my heater and while the 2nd battery box is cool i dont want to give up my heater and also is the leg room the same?
the first link is if my transmission channel is still good and if not then the 2nd link is the 1 ill go with, also is there any other complete floor pans out there that are 100% finished like the 2nd link but with holes like the walcks link
https://walcks4wd.com/left-and-right-floor-patch-panels-best-quality-1945-1964-cj2a-cj3a-cj3b.html
https://www.kaiserwillys.com/vehicle/49-53-cj-3a/body/repair-panels/floor-panel-repair/complete-front-floor-pan-with-welded-braces-fits-46-64-cj-2a-3a-3b
https://boston.craigslist.org/nos/pts/d/amesbury-38-jeep-body-parts/6913784889.html
« Last Edit: July 15, 2019, 10:44:36 AM by Roughneck20 »
1950 willys cj3a
Online Rus Curtis
« Reply #4 on: July 15, 2019, 08:35:19 PM »
Mike,
I personally don't have any experience with military vehicles but it's my understanding the tubs are all the same dimensions between these two so splicing "should" work.  I hope someone else with more knowledge confirms.
Offline MikeP
« Reply #5 on: July 16, 2019, 07:01:55 PM »
or if i used the m38 cowl could i still fit my heater if i removed the 2nd battery box and just kept the lid
1950 willys cj3a
« Reply #6 on: July 16, 2019, 08:30:04 PM »
Russ Curtis is correct. Dimensionally, the M38 tub is the same as the 3A tub.  The M38 also has a glove box in the same general area as the battery box.  If your heater is a Harrison, I don't think it will fit in the standard mounting position.
Although I couldn't get your Craigslist link to work, I found the tub you referred to.  It would be a steal at $400.00.
Offline MikeP
« Reply #7 on: July 23, 2019, 05:09:30 PM »
well i just got off the phone with willys overland and for just a tub its 3700 unknown if that includes shipping i forgot to ask but for a perfect tub i might go with it
1950 willys cj3a
Offline mtnman37879
  • Plays With Jeeps
« Reply #8 on: July 23, 2019, 09:07:21 PM »
I haven't bought one yet but I plan to in the next month or so. These are the best prices I have found, $2900 picked up in Nashville TN
https://ccsurplus.ecwid.com/JEEP-PARTS-c25378432
« Last Edit: July 23, 2019, 09:08:53 PM by mtnman37879 »
