Author Topic: Hit and Miss tractor?  (Read 6915 times)
Re: Hit and Miss tractor?
« Reply #15 on: March 06, 2014, 08:43:32 PM »
I took a couple more pictures today...still no sign of life at the shop...lots and lots of implements/engine parts you name it in the yard....no dog!
It's gear drive, and on the head cover the holes are marked "prime"
Just looking at the size of the gears and the chain drive it must have been a real crawler...
and maybe differential braking?
« Last Edit: March 06, 2014, 08:50:39 PM by 1955CJ-5 »
« Reply #16 on: March 06, 2014, 09:56:56 PM »
I see band brakes around the big drums where the drive gears are. I know what the engine it is too! Looks like an Edwards with the back cover off and someone removed the hopper and brazed on a plate to make it tank cooled instead. So then it is not a 2 stroke. The engine is worth getting!!! That tractor needs to be saved!
http://www.youtube.com/watch?v=vmK0MNwwvqA
Anyone care to speculate what the shift pattern looks like?� I guess it does not matter too much, in gear is in gear. :D
Zeke
It looks like an SM420.
« Last Edit: March 06, 2014, 09:58:21 PM by garage_gnome »
« Reply #17 on: March 06, 2014, 10:19:45 PM »
Someone sure went through a lot of work to engineer and build this tractor...I was a little surprised that there was no PTO pulley....
With that huge fuel tank it was meant for some long run times....
« Reply #18 on: March 06, 2014, 10:28:01 PM »
One could be added to the flywheel pretty easily.
