Author Topic: 50 CJ3A "Nuthin' Fancy"  (Read 98378 times)
Re: 50 CJ3A "Nuthin' Fancy"
« Reply #75 on: March 21, 2017, 08:20:24 AM »
Wow really nice work !
Offline MikeC4193
  • Who doesnt love a Jeep??
« Reply #76 on: March 23, 2017, 07:43:48 AM »
Havent been on here in forever ...I redid one in 2013-2014 (1947 CJ2A) that was in about the same shape...yours is coming along great...I am in upstate NY (Albany NY) so I know the feeling with all the rust and such...keep on digging for sure...looks awesome from here...
MikeC
If it wasnt for the Jeep we would be eating rice or and drinking warm beer.
Offline JeepFever
« Reply #77 on: March 28, 2017, 11:25:38 PM »
Amazing work!!   My project Hoover has stalled,   no regrets there because life is good,   but you sure have me salivating to get back to work.  . . . So inspiring what you have done!!
Keep posting . . you can never post too much.  haha
« Reply #78 on: May 05, 2017, 03:03:06 PM »
Hey folks here's an update...more metal work:
I pulled the hood from my shed and started to clean it up to assess it's condition. And it was pretty bad. The hood
had been caved in a few times, and the center flange was stretched and cracks progagated away from that spot.
see pic 1
Also most of the spot welds holding the two halves together were broken and it just sagged in place. I drilled out the
spot welds and also removed the rear brace so I could completely fix it all up along with new coatings. Earlier i
commented on how this thing had thick red oxide primer and now I'm kind of thinking this was original? I saw no
evidence of prior repairs (filler or dent repair).
see pic 2
Once apart I replaced the stretched flange sections and welded the cracks.
see pic 3
see pic 4
I welded the hood halves back together and noticed the straightened hood now had some huge bulges.
see pic 5
see pic 6
I kept going and welded in the newly coated rear brace. The hinge was almost rusted solid but some sandblasting and
working it back and forth freed it up fine.
see pic 7
Once welded completely I had to tackle the huge oil can issue. I tried using my propane heat method but it was slow
going and I couldn't get all the bulges out. I ended up cutting long slits in the forward part of the hood which
revealed how much stress there was...the slits closed right up, I recut the slits to get the proper weld gap and
welded them back up.
see pic 8
After this the hood was flat although hideously ugly with fine textured "tool marks". The forward part of the seam was
still floppy so I welded it to where the flanges begin (about 3 inches). Not stock but stronger now. I cringe when I
see folks sitting on these hoods...how do they not cave them in? They're so weak...
The welding on the brace curled the hood up a bit at the rear corners so I still need to do some tweaks there, but
overall the hood will cut it. A skim of filler should get rid of my hammer work. This hood was the biggest challenge
and took a ton of hours. Still, my labor is cheaper to me than a new hood!
After that I tackled some of the easy stuff...I drilled a bunch of missing holes for the footman loops, and found the
original panels were excellent for finding the positions for some holes such as the spare tire wood anti-vibe "brace".
I started another thread about how I found holes for the spare tire wood block on both sides of the Jeep, and we came
to the conclusion it's possibly because someone goofed up and used a passenger raw stamping for the driver side. Eh,
who knows, but I ended up using the driver panel clamped to the passenger side to transfer the hole locations....
see pic 9
I cut off the gas tank strap brackets from my old panels and welded them onto the new tub too. I purchased a new OMIX
ADA gas tank and fit that in as well. I am using conveyor belt rubber for body mounts and I can use this same stuff
under the gas tank too.
see pic 10
It's about 1/4" thick and works great. That gap will also allow room for the bolt head for the body mount under the
tank (although I ground it to about half thickness for more space too).
see pic 11
see pic 12
I very carefully measured and remeasured the position for the gas tank filler panel and finally welded that in. There
was enough play between that panel and the body opening to adjust it for best fit around the installed gas tank neck.
see pic 13
I also started to go through all my boxes and pull parts out for sand blasting. It's surprising how good some of these
neglected parts came out....they're ready for more decades of use...
see pic 14
The windshield is the last major job and it's in rough shape.
see pic 15
The biggest problem is the sheet metal at the top...it's rotten from having a hardtop flange overlapping the front,
and it needed replacement. There is a strip that I presume is for a soft-top, and that was also rotten. It popped off
rather easily. I see that these are being reproduced, but Walcks is out of them. Also, some don't come with the
backing piece, although that would be easy enough to fabricate. Anyway, I carefully drilled out the spot welds and
made some cuts to remove the bad section.
see pic 16
see pic 17
continued next entry....
« Last Edit: July 15, 2017, 10:30:10 PM by squidtone »
« Reply #79 on: May 05, 2017, 06:20:44 PM »
The patch must have a "z" shape folded in to serve as the windshield gasket flange. The offset is 1/4" or so, and I have access to a cheapo bender, but it can't do two folds that close together. So I did it by hand with wood.
see pic 1
I didn't have a long enough piece in my leftover sheet metal to make it one piece, so I made two and welded them together.
see pic 2
Then I cut out the shape and test fit.
see pic 3
see pic 4
see pic 5
Welding it up.
see pic 6
Since many of the piece-parts are blasted and primed I am putting some stuff together and test fitting. It looks like a Jeep kinda sorta...
see pic 7
Working on seat frames now, then probably get ready to remove the tub and finish all welds, and add some strengthening plates under the seat legs, center soft top brackets, etc. Also thinking about how to wire this thing up. I may just completely build it up, then take it apart for paint at the end. Be back soon I hope!
Dave
« Last Edit: July 16, 2017, 08:03:26 AM by squidtone »
« Reply #80 on: June 04, 2017, 10:04:40 PM »
[size=11]June 4th, 2017
Fun projects lately. I've been assembling the Jeep which is fun because I can see the Jeep as a working complete vehicle rather than a pile of dirty parts. I've never driven this Jeep, and never sat in it either since it was such a revolting mouse habitat. As I indicated in my last post I was thinking of taking the tub off to finish welding it up and perhaps starting the paintwork. But I don't have the budget right now so I'm going to just put the thing together. Probably better to do this now since all systems need to be COMPLETELY redone (fuel, wiring, interior bits, etc, etc)
The first thing for me was to repair the seat frames. These seats still had their spring sets and covers, but the mice claimed most of the jute and carried off alot of the gray vinyl.
see pic 1
I got the driver seat in with no issues and drilled in the floor holes for the legs. I ended up making new "feet" for both seats...these are the rear tabs that sit on the edge of the rear floor. The originals are simply an "L" shape but don't offer good support and I had some cracks. I see from Bob W's book that Willys changed to two strut legs in '52 or '53, so I duplicated that.
see pic 2
The passenger seat did not fit into the new floor/toolbox config. I suspect the OMIX ADA tool box I put in is not the same dimension as the original, so the front mounts sit farther back by about 3/8". So this means the seat won't settle all the way onto the wheelwell tab. You can see here that to settle in against the rear wheelwell the front pins are forward of their intended sockets.
see pic 3
I decided to cut the frame tubes and remove 3/8" of an inch.
see pic 4
I welded them back together and the seat fits perfect now.
see pic 5
I got some conveyor belt rubber and made up all my body mounts, and installed them (minus a few I can't put in until I get the tub off to drill holes).
see pic 6
I also did my final fitup of the gas tank. Since I was there I got some 1/4" brake line and made up my gas line. In order to fit this up, I had to drop the exhaust, remove the brake and clutch pedal set up, and also the front fender. What a domino effect. I got the fuel line all beautiful, got some nice line clips, and some slotted screws, and put in the line (still need the insulator stuff for each clip).
see pic 7
I had hoped to re-do the original flexible fuel line fittings at the pump end, but I could not find rubber fuel line in this size to re-use them, (a sort of compression type fitting set)
see pic 8
Instead, I simply made my own inverted flare fitting with a barbed fitting end for now and I put in a 1/4 rubber fuel line to the pump. When fiddling with that, I surveyed the pump that was on the block and confirmed that I had been running it (during my chassis testing) with a huge leak that pumped gas right into the engine. The engine oil is full of gas. I was avoiding investigating this because these combo gas and vac pumps are pricey. Even the rebuild kits are crazy. After looking into it further, it seems that a fuel pump listed for CJ3B's will work fine, and the 17709.03 OMIX unit is less than 80 bucks, it's just not correct for a 3A. I can't justify a completely correct resto so the reasonably priced 3B pump is fine for now.
When I took out the pedals, I decided to fix the brake pedal slop. I ended up buying bronze bushing stock from McMasterCarr and boring out the pedal in order to bush it with the bronze. A 4" length of this bushing material was 16 bucks.
see pic 9
The bush needed honing after to fit over (the new) pedal cross tube and I used a wheel cylinder hone to get it to size. It worked pretty good.
I also fabricated a clutch cross shaft rod with clevis rod ends to replace the simple double
ended "L" rod.
see pic 10
see next entry...[/size]
« Last Edit: July 16, 2017, 08:07:29 AM by squidtone »
« Reply #81 on: June 04, 2017, 10:08:00 PM »
[size=10]I started to inspect the gauges and in particular was wondering about the speedometer condition. I salvaged the old speedo cable and wirewheeled the rust off it, then cleaned it, straightened it, and hooked it up to the speedo to see how it worked. The speedo was very jumpy, and since the glass was dirty inside and out and the bezel was rusted, I thought I'd take it apart.
I carefully unfolded the bezel flange and managed to get it apart no problem. It was in perfect condition inside, but I was glad to be able to sand blast all the parts with the delicate internals removed.
see pic 1
The internals seemed fine and I think only needed the bushing cleaned. I flushed it out with alcohol and noticed that this unit has a simple brass plug on the cable boss with a wick hole, so it's easy to re-lubricate.
see pic 2
I used Singer sewing machine oil. I chucked the cable into my drill and the unit works super smooth now! I polished the glass with some Mequiars super fine paint polish and it's ready for some paint and reassembly.
see pic 3
I've started to think about the electrics, and I'm making plans now. I've cleaned and tested all the old switches, and it all seems good. Even the gas gauge works. I believe I've found a way to modify the Signal Stat 900 (to add directionals) I have to work the front parking lamps with a single filament. I'll make a detailed report on how I do this. That's the May update! Hope to post again soon![/size]
« Last Edit: July 16, 2017, 08:11:05 AM by squidtone »
« Reply #82 on: July 16, 2017, 02:26:58 PM »
July 16, 2017
I've made some headway on the re-wiring. With some books on car electrics and some internet research I came up with a fairly simple, modern system that is mostly hidden. Initially I was thinking of keeping it mostly stock, but I had converted to 12V already, and I thought if I did make this Jeep a snow plow rig, having a rugged electrical system would be best. Basically I'm adding fuses to everything, and using relays for the horn, lights, as well as one relay for an accessory only fuse panel for turn signals, and future stuff like a heater blower motor, etc. I did some shopping on Amazon and bought a pack of relays, some fuse blocks, and wire. I had some single row terminal blocks laying around, and I used them for now, but I'll convert to double row when I rip the Jeep apart for paint.
I used an aluminum plate to serve as the fuse "panel" with some feed through holes and locations for my terminal strips.
see pic of panel layout
There's not behind the dash as far as mounting locations, or wire routing space for the matter. So I got creative and made 4 bracket arms to spread out to various locations to mount the panel. I  put it up underneath on the driver side, completely out of view, but easy to get to to inspect fuses or relays. I also made a small steel rod traversing from the middle of the firewall over to the panel to simply zip tie my new harness to and keep it from interfering with the parking brake, gauges and speedometer cable.
see Pic of panel with brackets
see Pic of panel installed.
I got a 7605 IC along with some capacitors, and made up a 5V supply for the gas gauge. The heat sink is simply through a standoff into the panel. The regulator is only for the gas gauge.
see pic of 5V regulator
And, with the inspiration from athawk11, I made up my own battery clamp. I cut strips of some 16 gauge steel and hammered and bent some shapes, drilled some spotweld holes and welded it up. It came out pretty good! And it looks old school. I even made a strap to connect to the passenger fender.
see pic of battery hold down...
I'll update when I get the turn signals and lighting done....
« Reply #83 on: September 24, 2017, 08:43:09 PM »
[size=12]September 23, 2017
Hi folks. Busy summer, work has been sl-owwww.
However, my first cut at the complete wiring job is done. Happily, everything worked right off the bat. I'll touch upon a few things I didn't mention before, and then get to the basics of the re-wiring.
First thing I did for the hoot factor (pun intended) was to wire up the Autolite horn. A while ago I rebuilt the horn as a fun little side project. I made a monster 1 ohm resistor with some nichrome wire to drop the voltage down to about 7V or so. I put the nichrome "resistor" into the horn body and insulated the wire with ceramic beads to be safe with the resistor heat during use. Before bolting it all back together I cleaned the contacts with fine sandpaper, painted the external parts, tuned it, and it works pretty good!
I re-used the horn button and switch which were in fine shape. One thing I always wondered about is how the wire doesn't wear out from twisting around in the column when you turn the steering wheel, but it appears that the contact simply slips (rotates) as you turn the wheel keeping the wire from twisting. Seems to work.
And I've now got that classic "beep beep" sound.[/size]
« Reply #84 on: September 24, 2017, 08:57:39 PM »
[size=12]After the fun part, I continued with the install/upgrade by filling my panel with relays for the horn, accessory fuse panel, and the high and low beams. There are two fuse blocks on the panel, one "always hot", and one for accessories.  I used standard (ugly) 14 and 16 gauge pvc jacket wire. I regret not getting a proper pallette of colored jackets with tracers. Better yet would have been braided stuff, but plain wire will do for now.[/size]
« Reply #85 on: September 24, 2017, 09:01:58 PM »
[size=12]I had to do some head scratching to figure out what I wanted to run as any later decisions would alter where all my wire routing would be. First thing I did do was decide about how to wire the starting circuit.
To ease the clash and harshness of the starter pinion gear on the flywheel (due to running it at 12V instead of the proper 6V), I decided to integrate a Ford style solenoid. Doing this allows me to jam the starter pinion into the flywheel ring gear via the foot pushrod without elecric power. Once jammed in there, I turn on the starter motor by turning my replacement ignition switch to "start"(new one has a "start" position) to power the solenoid which then powers the foot switch, which turns on the starter. Starter pinion clash and "stripping" seems to have ended with this mod.
The solenoid is mounted on the passenger fender and the input stud is the new tap-off point for power to the "always hot" fuse panel under the dash. In the first pic you can see where I attached the alternator charge wire, positive battery cable, and the 10 gauge wire that goes to the fuse panel. In the fuse panel picture above, you can see the other end of the 10 gauge wire is installed onto the right hand fuse block stud. On that "always hot" fuse block stud I also ran the "sense" wire for the Delco 10SI alternator. It's best to put the sense wire to where most of the power will be drawn from. Incidentally, I'm using the Delco 10SI in a 3 wire configuration so I fabbed in a "gen" light in a metal tab which I mounted to one of the steering column bolts (I didn't want to cut another hole in my steel dash panel). The "gen" light is simply a bulb in series in the field wire for the alternator.
With that done, the Jeep could now start, run, charge and shut off. [/size]
« Last Edit: September 24, 2017, 09:05:45 PM by squidtone »
« Reply #86 on: September 24, 2017, 11:08:15 PM »
[size=12]Next was to figure out how to add turn signals. I ran into the classic problem for these old rigs: how to add turn signals to a vehicle with single filament front parking lamps. The problem is that the 900 series Signal Stats don't allow using the same filament for parking lamp operation and turn signalling. The 800 series Signal Stats WOULD allow "dual function" on the front filaments, but single filament front parking lamp vehicles haven't been made for decades, and the old 800 series Signal Stats aren't made anymore.
One solution is to add dual filament housings to the grille but that generally involves drilling out the grille to fit a larger two filament housing. I didn't want to do this. Investigating the internals of the Signal Stat revealed that the old 800 series contacts and sliders design is still "baked in" to the newer 900 series and could be modified to have dual filament functionality for the front lamps.
The mechanical system in the Signal Stat has 2 sets of 2 sliders and contacts which are moved by the signal arm. The rear sliders have input contacts for both turn signal power (flasher) and brake lamp power, but the front section only has one input for turn signal power. You can see that one whole row of contacts is left out.
To add two inputs, I drilled out the terminal strips over the front lamp sliders and added turned down brass machine screws to fill in the missing contact sockets. The outermost terminal strip had to be cut in order to create a new "input" for the parking lamp. When at rest, the parking lamp input passes on through to each front lamp filament. When the one slider or the other is deployed by the signal arm, the flasher signal is directed to one side or the other.
(To be continued)[/size]
« Last Edit: September 24, 2017, 11:10:25 PM by squidtone »
« Reply #87 on: September 25, 2017, 09:59:05 PM »
[size=12]I made up a tube and welded it to a clamshell clamp. I ran all the wires to and from the signal stat through the tube to keep it neat. The clamshell simply screws together around the steering column. I grounded the Signal Stat through the slider mounting screw inside the case and ran that wire to a ground lug on the fuse panel. You need to ground the housing to get the indicator bulb to work!
The turn signals work great, and the single filament front parking lamps work like original when the light switch is pulled "one click" out, and get interrupted by the flasher when I use the Signal Stat!
I'm experimenting with LED's for the front lamps with a simple flat plate mount. I used LED "penny lites" made by Blazer. They are very bright and rated to have a very wide lighting pattern. I will also try a LED replacement #97 in the original sockets to see how they look. I know originally the parking lamps were clear, but I like the amber. I should say also that I bought a flasher unit that is meant for use with LED's. You can see it installed on the fuse panel in the pictures above.[/size]
« Last Edit: September 25, 2017, 10:10:38 PM by squidtone »
« Reply #88 on: September 25, 2017, 10:28:59 PM »
[size=12]Finally, I ran new wiring for the lighting. Here too I used modern PVC jacketed stuff, but most of it is covered by ashpalt loom material I sourced from a local NAPA. I used the loom clamps kindly sent to me by 1955CJ-5 a few months ago. These keep the loom in place as it runs to the back in the frame rail.
The original headlight socket terminals are easily re-usable. Willys used nice quality electrical bits (although the cloth covered wire was mostly missing the cloth!). I even re-used the flag terminal for the headlight bulb ground.
It was time to sandblast and clean all the headlight bucket housings and hardware, and also refurbish my used NACO tail lights. Everything was painted and put back together. The hardware for the headlights was also good quality stuff and cleaned up nice. I made up a piece of heavy steel wire into a hook to get the springs looped over the dished sockets.
The NACO tail lights look great. I'm happy I chanced upon these units with the chrome bezels and glass lenses.
So that's it for now. I'm at a stand at this point: I'm not sure if I should tear the Jeep apart now to prep for paint, or keep going and pull out the Koenig half cab and restore that over the winter. I'll post again soon I hope.
Dave[/size]
« Last Edit: September 25, 2017, 10:30:25 PM by squidtone »
Offline LeeC
« Reply #89 on: October 09, 2017, 05:30:28 PM »
I just read your entire thread, incredible workmanship. You've done a lot of I thought of doing but didn't dare, I don't know how many times I've tried shrinking sheet metal but can't get the hang of it. I thought of the pickup bed for a floor plan but haven't got there yet. My jeep is 47 & 48 CJ2, 52 M38 and a supersonic engine out of a 54 Henry J (so far). Once again great work.
