I had taken apart my (presumably) original oil pump and all the clearances were in spec, but I decided to really clean it out and took off the bypass plug. I found the spring was broken and someone had stuffed an old set screw in there to (I guess) try to compress the spring to increase oil pressure, or perhaps overcome the problem of a broken spring coil. This was enough of a mess that I decided to just buy a new oil pump. I got a Sealed Power unit from RockAuto, and the box indicated it was manufactured in USA in 2001. I crossed my fingers (hoping that it isn't one of the poorly made ones that seize) and bolted it on.
I took some time to "rebuild" the distributor also. I knocked out the lower retaining ring pin and then installed new bushings (can still find bushings at the hardware store) adjusted the centrifugal weight springs, and reset the spacer to be sure the shaft floats in between the upper centrifugal bracket and lower retainer. There was a precision washer that was too thick which moved the distributor body too high, which made contact with the upper thrust washer and there was alot of wear. I believe the shaft should bottom out in the oil pump and the distributor shaft should "float" with equal distance between the upper and lower thrust washers. I made a thinner washer and got it centered.
I installed the distributor statically, using a multimeter to check when the points open. I wasn't sure where the distributor body orientation is to be, so I made the oil filler go to the 10 o'clock postion. I may re-do this as I think I'd prefer the oil filler in the 2 o'clock position.
The engine went together fine and fairly quickly. A close inspection of the clutch disc revealed it was very worn out, so I bought a new clutch. While waiting for that, I decided to make a double bolt bracket for the top two engine to bellhousing fasteners. I had a whizbang of a time trying to loosen them since you need two wrenches and it's so tight there on the driver side. I realized what that hacked out big hole was for next to the gas pedal (that I welded up during body resto) on the firewall....access to that driver side engine bolt! So I made a template and cut up a piece of 1/8" steel plate, made a jig, and welded the bolts and metal together. Now I need only one wrench to tighten down the top bolts. It worked nicely!
Finally, shockingly, I was able to adjust the exhaust flap weight and got it adjusted as it should be for cold starts. I was even able to reuse the sheet metal tab used as a stop for the end of the bimetallic spring. It's odd what survives and doesn't in these old Jeeps.
I painted the engine, and it looks better than it did.
