I've been digging through my dozens of sorting bags and boxes and taken all the piece parts and hardware that are to be gloss black and finally gotten them painted. This includes the fan shroud and shifter cover. I used NAPA (Martin Senour) paint for these parts and I'm very happy how this stuff sprays. It does take HOURS to cure up enough to handle, but it looks so good I'm fine with this minor complaint.
I had intended to get a new dash data plate but found that the repro's seem to be simply screen printed, and the fonts don't match up to the originals. So, I made an attempt at a "refurb" of the plate I had. It was eroded, and had no paint left. It looked terrible. But since it's embossed, the highlights can be sanded...so I fogged it with satin black, then wet sanded the plate on a flat surface. Alot of the fresh paint came off unintentionally from sanding, but I touched it up with brush work, then coated it with matte clear. Sheesh, I like it...it looks old but pretty good.
By the way, I had a * of a time finding original type slotted fasteners. I scoured many hardware stores, yet still had to order a bunch of stuff from McMaster Carr. I should say I wanted to re-use as much original hardware as possible, but alot of it was very poor condition, so I made the decision to replace many bolts with new. It seems as though orginal hardware was mostly zinc plated, so that's what I replaced them with. I'm bummed it all has 'modern" initials on the bolt heads, but I suppose not many will scrutinize bolt head markings.
