Author Topic: Our Ky jeep, Pap.  (Read 13285 times)
Offline GregL
  • We will fix things until they are broke.
Re: Our Ky jeep, Pap.
« Reply #30 on: October 31, 2018, 11:20:23 PM »
Thanks for all the encouragement. I�m working out of a remote garage and lots of OT lately, lining up hoist to pull the engine within the next week. Soon as I do I will post some more pix.
Stay tuned!
Greg
Greg
1949 CJ3A project S/N 14749
Body S/N 13379
Offline GregL
« Reply #31 on: November 02, 2018, 10:05:31 PM »
starter piinon housing upper mount ear is broken off. guess ill be looking for a new housing or starter complete.
Greg
Body S/N 13379
Offline GregL
« Reply #32 on: November 04, 2018, 10:01:40 AM »
Ok here�s something that should be the FIRST thing all you �old timers� will tell anyone �like me� who is new to the old jeeps.
THE LEFT SIDE WHEEL STUDS ARE LEFT HAND THREAD!!!
Lol, only rounded one and one stud on the left rear is right hand thread! Doh! :o
Greg
Body S/N 13379
Offline stony
« Reply #33 on: November 04, 2018, 01:23:50 PM »
Been there, done that LOL!  Look for the �L� or �R�  on the stud, kind of hard to see sometimes.
Terry
« Reply #34 on: November 04, 2018, 08:07:21 PM »
Interesting that your's were mixed on the same hub! I have 3 right hand hubs and one left.
Never take it to a tire shop without supervision!
The original left hand lug nuts have a little notch between the flats....not sure about the reproductions...
« Last Edit: November 04, 2018, 08:10:48 PM by 1955CJ-5 »
Offline GregL
« Reply #35 on: November 10, 2018, 08:41:37 PM »
Got all the lug nuts off, will standardize the one oddball at some point down the road. Big milestone, engine is out, temperature here getting cold so things will be slowing down
Greg
Body S/N 13379
Offline GregL
« Reply #36 on: November 26, 2018, 06:32:52 PM »
Pulled the head off today, aft cylinder looks like water damage, I think that�s the seized piston, the head gasket doesn�t look blown so ...? Won�t budge. Also have difficulty getting the distributer to move, remove!
Greg
Body S/N 13379
Offline GregL
« Reply #37 on: December 16, 2018, 11:49:27 AM »
Quick question! Will the pistons come out the bottom? The back two pistons are seized. I�m thinking taking them out the bottom would do less damage!
Greg
Body S/N 13379
« Reply #38 on: December 16, 2018, 07:14:57 PM »
I've taken them out through the bottom, but I had the crank out.� Not sure if there is enough room without the crankshaft out of the way.
« Last Edit: December 16, 2018, 07:15:19 PM by athawk11 »
Offline mtnman37879
  • Plays With Jeeps
« Reply #39 on: December 16, 2018, 11:53:27 PM »
Try some Sea Foam Deep Creep before you go to the hammer. When it comes to penetrating oils I am hard to impress and the sea foam has impressed me. Also the piston won't come out the bottom. The bore has worn where the piston travels and the bottom of the bore is the smallest. They come out the top.
« Last Edit: December 16, 2018, 11:53:58 PM by mtnman37879 »
Offline GregL
« Reply #40 on: December 18, 2018, 06:17:18 AM »
Last one came out in pieces but there out!
Greg
Body S/N 13379
« Reply #41 on: December 19, 2018, 08:02:27 PM »
I'll respectfully disagree Mtn-pistons can and will drop out the bottom w/crank removed.. Muley..
Offline Lee
  • Will-is enthousiast
« Reply #42 on: December 19, 2018, 08:12:47 PM »
Yes they will  :D as Tim stated,�With the Crankshaft Removed�, I�ve done it several times removing stuck or seized pistons on L&F Head 134�s. This saves the connecting rod from damage trying to pound the piston up through the top!  :o.....
This is a very nice looking 3A [ch128077][ch127997], Will be following your progress!...
Lee ;)
Offline gmcjr
« Reply #43 on: December 19, 2018, 09:00:09 PM »
Yes they will� :D as Tim stated,�With the Crankshaft Removed�, I�ve done it several times removing stuck or seized pistons on L&F Head 134�s. This saves the connecting rod from damage trying to pound the piston up through the top!� :o.....
Lee ;)
What Lee said..... Been there, done that.
Yes, the bore is smallest at the bottom due to less wear. But, it�s still the roughly same diameter as the rest of the cylinder was when it was first bored.
As a general rule pistons dont grow with wear, cylinders don�t shrink with wear,� if the crank is out of the way, plenty of room in a 134 Willys block.  :-?
« Last Edit: December 19, 2018, 09:02:59 PM by gmcjr »
Gary in N. Texas
51 CJ-3A (old Trusty)
52 Ford 8n (ugly duckling)
46Farmall B (old Rusty)
18 Wrangler Jk
Offline GregL
« Reply #44 on: December 31, 2018, 04:01:41 PM »
Almost ready for the machine shop, time for cleaning and initial detail inspection
Greg
Body S/N 13379
