Author Topic: CJ's 49 3A  (Read 12993 times)
Offline bverboy
Re: CJ's 49 3A
« Reply #15 on: February 02, 2017, 06:03:51 AM »
ill look you up bob when I remove my tranny.. thanks.
Offline CJ4CJ
  • '49 CJ3A, '48 CJ2A
Re: CJ's 49 3A
« Reply #16 on: February 02, 2017, 07:56:17 PM »
Thank You Bob!!
Offline CJ4CJ
Re: CJ's 49 3A
« Reply #17 on: February 04, 2017, 04:08:55 PM »
Question: the CJ2a paint scheme doesn't indicate the color for the intake and exhaust manifold.  Are they semi gloss black like the rest of the engine?
Offline bverboy
Re: CJ's 49 3A
« Reply #18 on: February 26, 2017, 05:22:03 PM »
can that number be stamped anywhere else on the tranny?
Re: CJ's 49 3A
« Reply #19 on: February 26, 2017, 08:08:30 PM »
No, but the date the case was cast should be on the left side of the transmission case.
Offline bverboy
Re: CJ's 49 3A
« Reply #20 on: February 27, 2017, 06:33:39 PM »
my tranny number is c121 with a space then the number 3.. when was it made? then at a slant is the number 43
« Last Edit: February 27, 2017, 06:34:59 PM by bverboy »
Re: CJ's 49 3A
« Reply #21 on: February 27, 2017, 06:43:49 PM »
Looks like March 12, 1951. What is the serial number of the CJ-3A?
Offline bverboy
Re: CJ's 49 3A
« Reply #22 on: February 27, 2017, 08:06:56 PM »
the serial plate is gone.. why?   [smiley=huh.gif]
« Last Edit: February 27, 2017, 08:10:22 PM by bverboy »
Re: CJ's 49 3A
« Reply #23 on: February 28, 2017, 11:55:36 AM »
the serial plate is gone.. why?� �[smiley=huh.gif]
Just to see if I'm correct with the transmission assembly date. It is unusual to have all those extra numbers that you describe.
Offline bverboy
Re: CJ's 49 3A
« Reply #24 on: February 28, 2017, 07:11:03 PM »
hmmmm  gotcha.. no tags on the fire wall so I will go with your expertise as the tranny and transfer case look like they never been touched
Offline CJ4CJ
Re: CJ's 49 3A
« Reply #25 on: March 13, 2017, 02:09:25 PM »
Does anyone know how to remove this type of shackle?  Remove center bolt and then pry bar it off.  I'm tempted to just get the sawzall out since I'll probably go back to original C shackle.  This is what I did on the other side after Kroil, Heat, Impact wrench didn't work.
Offline CJ4CJ
Re: CJ's 49 3A
« Reply #26 on: March 13, 2017, 02:12:03 PM »
sorry user error.  Here are the two pictures that I'm asking how to remove.
Offline mtnman37879
  • Plays With Jeeps
Re: CJ's 49 3A
« Reply #27 on: March 23, 2017, 09:27:56 AM »
sorry user error.� Here are the two pictures that I'm asking how to remove.
The plate looks like a slip fit on the grease zerk side, the opposite side seems to be a press fit. The center bolt held the two sides together. After years of rust, I'd tap the grease zerk side a few times with a hammer. If there's no movement, I'd use a sawsall.
