Author Topic: Ryan_M's 1949 CJ3A  (Read 48056 times)
Re: Ryan_M's 1949 CJ3A
« Reply #15 on: November 18, 2015, 09:40:56 PM »
You freakin crack me up.  ;D.  Are you this much fun at parties?
Now that's funny. I am the most boring person you will ever meet at a party. I much prefer to stay in the garage and tinker on this old junk instead.
« Reply #16 on: November 19, 2015, 09:03:56 PM »
Summer vacation photos from the La Brea Tar Pits Touching Pool?
No, never been there but I did drop the oil pan tonight and I'm pretty sure I still found a Woolly Mammoth without having to endure the indignity of a TSA pat-down to do it.
From the looks of this pickup screen I believe I have also proven beyond any reasonable doubt that Go-Devils don't really need oil after all. Save your money - buy beer, not oil. Thank me later.
What a mess. Most of this ended up in my hair (don't ask) but at least it's out of the motor.
And oh yeah, that Felpro Oil Pan Gasket "Set" you buy is called a "Set" because in addition to the oil pan gasket you know you are getting the cardboard package you didn't immediately open also contains the gasket for the oil pickup screen assembly. Only a moron would dig through every random box of gaskets in the garage looking for one of those before giving up and reattaching it using sealant instead. Oh well, now I do in fact have a spare pickup screen gasket stashed in a random box in the garage somewhere.
All this fun tonight after probably 60 miles of fire-free driving today - much improved over yesterday. It's unfortunate my coworkers are not sophisticated enough to discern residual electrical smoke from exhaust manifold leak fumes on my clothes. I had both yesterday and only one today. I was hoping someone would notice a lack of the former and congratulate me on my improvements. No such luck.�
« Last Edit: November 19, 2015, 09:13:34 PM by Ryan_M »
« Reply #17 on: November 19, 2015, 10:20:03 PM »
Perhaps that indescribable burnt-oil "Butch Wax" threw them off...
What a neat jeep....fix a little, drive a little...perfect!
« Reply #18 on: November 20, 2015, 06:41:21 PM »
Yumpin yimminy!
There's gotta be a market for that goo.  Maybe it could be the next anti-wrinkle miracle cream.
Your trio looks great together.  You should keep em together but I know how it goes. :-/
« Reply #19 on: November 22, 2015, 05:14:07 PM »
Freed from the curse of the yellow wheels and 4 hood latches!
Since I've been running with what I thought was a broken temp gauge I ordered and installed a new one.....which also didn't work. Hmmm....further investigation revealed that both temp gauges worked but this crusty old thermostat did not.
No doubt this was a major contributing factor to the moisture in the oil. New 180 degree T-stat has been installed.
And might as well get this out of the way too.
The source of exhaust manifold leak turned out to be a degraded gasket where the exhaust pipe connects. The bolt was completely rotted and I broke it off but was able to drill out the remains without damaging the original manifold threads (a personal first after numerous attempts over the past few years...). I also replaced a missing exhaust manifold stud where there had previously been just a bolt without breaking anything in the process - hallelujah.
I deemed the entire exhaust pipe system not worthy of further use and ordered a new set-up from Walck's along with some new fuel lines. I will be removing the rubber hoses and electric fuel pump in favor of a glass bowl mechanical one.
And "while I was in there" I adjusted the valves and cleaned what residual oil goop I could get at out from around the valves and throughout the PCV valve and plumbing. It wasn't as horrid as I expected after seeing what was in the oil pan but it wasn't great either.
Thanks for checking in� :)
« Last Edit: November 22, 2015, 05:15:12 PM by Ryan_M »
« Reply #20 on: November 22, 2015, 06:04:47 PM »
I think you need a dual carb setup on that jeep.
« Reply #21 on: November 22, 2015, 07:15:50 PM »
Definitely looks manly with the black wheels.  You're clicking right along with the improvements.  I'm enjoying this! :)
Offline Jeff_M
« Reply #22 on: November 22, 2015, 08:54:20 PM »
Call me weird but I liked the yellow wheels.  Nice thing about flat black, though, is that you don't really have to bother about the overspray.
« Reply #23 on: November 22, 2015, 08:59:32 PM »
I think the yellow would look good with quality paint job. This was not.
And yes, black is the preferred choice for those who detest masking off tires.
Offline BMIC
  • Weekend Mechanic
« Reply #24 on: November 23, 2015, 09:10:04 AM »
Not a fan of the yellow wheels, looks like they should have smiley faces on them.
What caused the oil to become jelly like? water leak? I've seen water/oil mixed gray but never of that consistency.
« Reply #25 on: November 23, 2015, 09:53:31 AM »
I am holding my breath that it is not a leaking head gasket or cracked block. My hope is that's it's just a lot of residual condensation that was never able to burn off because the engine never got warm enough. So far so good after the oil change and new thermostat but it's too early to know for sure yet.
Increasing the oil change frequency to at least once every 15-20 years will help too.
« Last Edit: November 23, 2015, 09:55:58 AM by Ryan_M »
« Reply #26 on: November 23, 2015, 02:02:05 PM »
The Model A looked about the same....probably just sludge from years of neglect....or greasy kid stuff....
« Reply #27 on: November 28, 2015, 09:22:30 PM »
[media]https://youtu.be/0RCLtKwzbvY[/media]
Big thanks to Mike in NH for the very helpful reference pics & info!
« Last Edit: November 28, 2015, 09:29:31 PM by Ryan_M »
« Reply #28 on: November 29, 2015, 06:45:29 AM »
Awesome
« Reply #29 on: November 29, 2015, 08:01:45 PM »
Cool set up.  But wait, I thought you had a little tank for the snow removal duties.
