Author Topic: DTFM33's CJ3A Build  (Read 7622 times)
Offline DTFM33
DTFM33's CJ3A Build
« on: May 30, 2015, 04:11:03 PM »
I have stopped by a few times over the years and received great help and advice. I have a 49 CJ3A my father in law gave me. Not bad shape. The resto that was done 20 years ago was not what I would call a real good one. My Father in Law just passed away a few weeks ago and my daughter and I want to restore the Willys. Started making a list of items I need to start with. (See below) So we pulled the front end off last week and got ready to do a rebuild on it. (Already have some great advice on that from a few members.)
So I started shopping on CL to see what was out there. I found an advertisement for a "Basket Case Willys" Wasn't really what I was looking for, but I went to take a look.
My immediate needs for my CJ3A:
Front end rebuild Kit.
Steering Linkage
Brakes all around. All wheel cylinders shoes, drums.
2 decent front fenders
Tail gate
Transmission gears
New floor panels.
This is what I found when I went to look.
« Last Edit: June 01, 2015, 02:31:20 PM by DTFM33 »
Re: CJ3A Build
« Reply #1 on: May 30, 2015, 04:32:48 PM »
Interesting tow rig,not sure I have seen anything like that before is that similar to an RV / car setup?
Body looks alright from what I can see in the pic
Offline DTFM33
Re: CJ3A Build
« Reply #2 on: May 30, 2015, 04:37:21 PM »
Floors are rough. Frame has been sand blasted and powder coated. Real dusty right now. It was in storage for a while
« Last Edit: May 30, 2015, 04:51:57 PM by DTFM33 »
Offline DTFM33
Re: CJ3A Build
« Reply #3 on: May 30, 2015, 04:38:50 PM »
This came in the basket too. Full set of 11 inch brakes.
« Last Edit: May 30, 2015, 04:39:21 PM by DTFM33 »
Offline DTFM33
Re: CJ3A Build
« Reply #4 on: May 30, 2015, 04:41:50 PM »
Why can't I post more than one picture at a time.
The basket case came with:
New front springs
New steering linkage
Master cylinder rebuild kit
Steering box.
Trans Case seal kit
« Last Edit: May 30, 2015, 04:43:14 PM by DTFM33 »
Offline DTFM33
Re: CJ3A Build
« Reply #5 on: May 30, 2015, 04:44:33 PM »
More stuff
Offline DTFM33
Re: CJ3A Build
« Reply #6 on: May 30, 2015, 04:45:42 PM »
Not sure I want to keep these hubs. Any advice?
Offline DTFM33
Re: CJ3A Build
« Reply #7 on: May 30, 2015, 04:47:14 PM »
All parts were bagged and tagged
Offline DTFM33
Re: CJ3A Build
« Reply #8 on: May 30, 2015, 04:50:57 PM »
Tranny gears look pretty good.
And a much needed Air filter.
Re: CJ3A Build
« Reply #9 on: May 30, 2015, 07:28:06 PM »
Nice score. I see 2A frame, fenders, and steering column. Hood probably is too but I can't tell from the pic.
You can use the fenders on your 3A but you will likely have to trim the driver's side one a little bit.
Offline DTFM33
Re: CJ3A Build
« Reply #10 on: May 30, 2015, 08:06:14 PM »
Is the frame usable on the 3A? Also, what do you guys think about the locking hubs?
Re: CJ3A Build
« Reply #11 on: May 30, 2015, 11:33:01 PM »
Using a hosting site like Photobucket is the best way I've found to post multiple photos in one post.
The 2A frame has some differences, but for the most part, 3A stuff will bolt right up.  A CJ3A frame is much stronger than a 2A frame, but that one looks to be in excellent condition.
The hubs look like a semi-modern version made by Warn.  If they work, I'd keep them.  If you're going for a more vintage looking hub, they show up on eBay fairly frequently.
