Author Topic: Starting on my 51...  (Read 14097 times)
Re: Starting on my 51...
« Reply #15 on: March 05, 2013, 08:48:23 PM »
Looks great!
Offline Comanche_County
« Reply #16 on: March 07, 2013, 09:30:01 PM »
and my wheels are back too...
Yeah you're making it look easy.   Good to see another 3A and MJ fanI  You even have MIA sticker like mine but I've got it on the MJ's back window.
Offline SteveB
« Reply #17 on: March 14, 2013, 08:17:31 PM »
Got a little work done today...
Pressed out wheel studs to separate drum from hub. (new drums going on)
Cleaned up original backing plate for paint...
Cleaned up transmission mount, also prepping for paint.
Got a little help bending my transmission skid plate back (was rubbing on front drive shaft)
« Reply #18 on: March 14, 2013, 08:45:11 PM »
While you have the drums off, you may want to think about upgrading them to the later CJ3B/5 drums so you don't have to remove the whole hub assembly to work on the brakes. It makes them more like modern brakes where you can just remove the drum. You don't have to swap backing plates or anything either, only the drums.
« Last Edit: March 14, 2013, 08:46:17 PM by garage_gnome »
« Reply #19 on: March 14, 2013, 08:51:08 PM »
You might want to put all RH wheel studs on too. Makes life easier. ;)
Offline SteveB
« Reply #20 on: March 15, 2013, 06:51:16 AM »
Have to keep that in mind..........for next time.  Got all my parts all ready. ;)
« Reply #21 on: March 15, 2013, 07:55:09 AM »
You can always send them back and wait for the other ones too.  ;)
Offline SteveB
« Reply #22 on: March 15, 2013, 08:04:23 AM »
Same inner diameter?  Do they use the same hub?   What year CJ3/5 are compatible with this swap?  You got me thinking....
« Reply #23 on: March 15, 2013, 09:02:26 AM »
Same hub and everything. Only thing you change is the drum. I'm not sure on the importance of the 3 screws that hold the drum on. I had a junk 3b so I swapped hubs and drums to make life easy.
http://walcks4wd.com/brake-drum-9-front-or-rear.html
Offline Ryan_289
« Reply #24 on: April 25, 2013, 09:45:12 AM »
Thats good to know.  My M38 was set up this way as well.  It just so happens that I have a 3b frame sitting in the backyard with good diffs.  Ill make this swap as well on my 48 2A.
« Reply #25 on: March 02, 2014, 12:39:15 PM »
Any updates on this project?
Offline SteveB
« Reply #26 on: June 02, 2014, 04:48:03 PM »
Thanks for asking...........been shelved for a while...life got busy then the boss pulled his own project into the shop (67 Sprint convertible - modding into GTO clone).� When we're slow we work on his project.� �Good thing though, as I am learning to weld on HIS car, so I am inspired to save as much of my original 3A tub as possible....when I can get back to it.
