Author Topic: Clutch x shaft pivot ball bracket broke  (Read 3090 times)
« on: October 07, 2020, 10:04:24 PM »
It started innocently enough.
I'm planning to replace the CJ-5 clutch this winter and wanted to know what pressure plate I had.
As the present clutch engages at about the last 1/2" of pedal travel before the free play starts, I'm thinking the disc is pretty thin.
I had removed the trans tower cover and removed the bell housing inspection plate.
I was depressing the pedal repeatedly and watching the throw out bearing...
Then it went Bang!
Lucky this happened in the garage!
The pedal went to the floor.
Thought I had broken the clutch fork.
Turns out you can remove it by manipulating it and sliding it out the inspection hole....you can replace it that way too.....it was fine...
More head scratching and wondering and finally i checked the cross tube...
Frame side pivot bracket had broken!
I removed it and noticed it had broken and been brazed sometime in the past.
This was a new break.
I welded it using the Turkey * method and cleaned it up with a welder's eraser ( 4 1/2"grinder)
It looks fine and works fine but will be replaced when I do the clutch...
The pressure plate is an Auburn 8 1/2"....
« Last Edit: October 07, 2020, 10:07:14 PM by 1955CJ-5 »
Re: Clutch x shaft pivot ball bracket broke
« Reply #1 on: January 02, 2021, 09:43:15 AM »
that's crazy Randy!  Last summer when I met up with Todd for a trip up around Ridge Road, my clutch was feeling weird.  Engaging right off of the floor, and when shifting, I was getting some grinding.
Back at home I crawled under the Jeep and found the nut that holds the pivot stud to the bracket on the frame was loose.  This caused the pivot tube to be at a weird angle.  Once I tightened it down, my clutch problems went away.  I'll put a washer and a nylock on there before next trail season.
Here is what I had going on:
« Reply #2 on: January 02, 2021, 11:28:13 AM »
That's crazy.
I had a fork fail in traffic.  Luckily, at the time I'd just recently practiced shifting without a clutch and was able to get home.  I got a similar "bang" and lurch.  Thankfully my foot was on the brake.
Offline tow hook
« Reply #3 on: January 03, 2021, 10:15:40 AM »
i got a brand new clutch, installed it and the throw out bearing was a good 1.5" away from the plate. i adjusted it for days, no luck. had a shop look at it, they broke the cable to the pivot rod !  i had a 9.5" pressure plate vs the 8.5"  the shop replaced it , that cost more then it should have :(
Offline Mark W.
  • Chug A Lug
« Reply #4 on: January 03, 2021, 02:42:16 PM »
If you are having clutch pivots coming loose or brackets breaking be sure to check your motor mounts. Its not uncommon on a lot of vehicles for a busted motor mount to allow the engine to roll over to the right and cause all manner of problems with old style clutch linkages.. Easiest way to check is to open the hood and look at the left motor mount while reving up the engine. There should only be a tiny amount of movement. Of course there are any number of ways a bracket could get damaged but its still a good idea to check the motor mount.
Chug A Lug
1948 CJ2A Tub and Title
1949 CJ3A Windshield
1957 CJ5 Frame and Springs
DIY Aluminum Hard top
