Author Topic: Water Pump  (Read 1642 times)
Offline PaulS
Water Pump
« on: June 06, 2016, 10:11:12 AM »
How do you disassemble a Willys water pump?  The shop manual says to pull the clip out and then use an "appropriate puller" to remove the pulley and impeller.  Are those just pressed onto the shaft?
When I tried to pull the impeller, it broke.  (It seems to be included in the rebuild kit that Walcks sells, so no big deal, if I can complete the disassembly with no further damage.)
Any suggestions?
-Paul
