Author Topic: Rear cap shims.  (Read 1272 times)
Offline ZekeD
Rear cap shims.
« on: September 29, 2013, 10:49:07 PM »
Ok, so now I know to call it the "rear Cap" rather than "The speedo housing"  (part no 7 )  But I am in trouble...How and why and to what extent do you "shim" the rear cap when you re-assemble the TC?   Is there an explanation, or do you shim until there is no grinding noise.   (my Uncle Ray's solution)
and while I am at it:  How do you extract the pivot pin (#28) from the shift levers?  Mine appears to have a cap on the inside....toward the bell housing. and part #29 is missing... Is it just a zerk fitting ???
Thanks Zeke
Re: Rear cap shims.
« Reply #1 on: September 29, 2013, 11:09:03 PM »
If you remove #30, #28 should push out towards the frame. #30 is a set screw with a square head and a hole drilled for safety wire.
The shims will be in there, and you can get more...setting the end play is a process, but may not be needed unless you rebuild the t/c...
Here is a link...
http://www.cj3apage.com/index/Tech_Tips/Model%2018%20Rebuild.htm
The procedure is way down the page in the assembly section
#29 is a zerk..
« Last Edit: September 29, 2013, 11:15:55 PM by 1955CJ-5 »
Offline ZekeD
Re: Rear cap shims.
« Reply #2 on: September 29, 2013, 11:57:20 PM »
Cool,  thanks
ZD
