Classifieds Ads => Buy, Sell, Trade => Topic started by: PeteS on March 30, 2026, 09:27:23 PM
Been a very long time since I've been on the forum. I've mostly lurked over the years. Downsizing and have a great deal of nice parts that I need to cut loose. Everything located in Canterbury NH, central part of the state. If interested, please send me a message with your exact shipping address and email address. From there, you can expect a prompt reply with a no-nonsense shipping cost.....Pete
Front driveshaft. For F-134 applications for sure. No dents, dings or scratches. Has been in dry storage in heavy plastic sleeve for many years. Slip joint is perfect and telescopes freely. It has original Spicer u-joints with no slop. No grease or crud accumulation. Clean. Collapsed OAL is 23.5" and extended OAL is 25". It may be NOS...Very nice piece at the least. $165.00 plus shipping.
(https://i.postimg.cc/RZwX2SZ1/20260328_114351.jpg)
(https://i.postimg.cc/3x2nz8xp/20260328_114409.jpg)
(https://i.postimg.cc/jSyZBxSC/20260328_114432.jpg)
**SOLD** Late 3B speedo in condition shown. This is out of a 59' CJ5. Will clean up nicely. Had been in cold storage for some time but it is functional. $40.00 plus shipping.
(https://i.postimg.cc/Nj3yxhbX/20260315_120657.jpg)
(https://i.postimg.cc/RZk3TrGv/20260315_120719.jpg)
(https://i.postimg.cc/pLw9BNkv/20260315_120708.jpg)
Good takeout e-brake drum and backing plate. Small parts on backing plate included. Use as-is or clean up as you wish, but shoes need to be replaced. It features the usual accumulation of dirt but it's grease free. I do have a rear bearing retainer with e-brake lever and speedo gears at additional cost if you wish. $45.00 plus shipping for the drum and loaded backing plate.
(https://i.postimg.cc/MKWRN8yd/20260315_101849.jpg)
(https://i.postimg.cc/CLFDXVjN/20260315_101842.jpg)
(https://i.postimg.cc/P52JpMQ0/20260320_163212.jpg)
(https://i.postimg.cc/T3Rh3sn6/20260320_163219.jpg)
Very nice clutch control tube for 3B and early CJ5. Not for 6 cyl. Used, but in terrific shape without galling or rounding out of any component. I keep hearing about people buying inferior/repro parts, with the tabs being welded/clocked incorrectly. It has some of the interior parts. (which I'd personally replace). Half the price of repro garbage. Pulled from low mile vehicle. $16.00 plus shipping.
(https://i.postimg.cc/q7YSDLSt/20260314_181456.jpg)
(https://i.postimg.cc/W3kKBZcY/20260314_181449.jpg)
Engine stay cable, used but blasted in terrific shape. Has a bracket on it and correct nut. $15.00 plus shipping.
(https://i.postimg.cc/4yRMs3JY/20260314_181323.jpg)
Two clutch control rods, measuring 10 3/4" OAL. One is new, other is excellent takeout without galling. $10.00 ea. your choice, first come first served plus shipping.
(https://i.postimg.cc/TPSFN9F0/20260314_181931.jpg)
Lot of take-off hub caps. These are original. Four are blasted/primed/painted OD and nearly perfect at $18 per pair. Some shelf wear. The other two have small dents but 100% usable, blasted and painted. Great for a trail rig at $12.00 for the pair plus shipping.
(https://i.postimg.cc/d0XpNBp9/20260314_182242.jpg)
**BOTH SOLD** NOS Seal Tested starter drives. Willys p/n 119597. I have two on hand. Not that easy to find. These are 9 tooth units matched for 129 tooth flywheels. For PrestoLite/AutoLite MCH-6203, MCH-6207, MCH-6215, MDM-6005 & MDM-6006. I personally would do more homework if you plan to use these for a floor start, 6 volt or pre 57' applications. I cannot vouch for the the wagon and truck/6-226 fitment.
1957-1968 Jeep CJ-3B
1957-1971 Jeep CJ-5
1957-1971 Jeep CJ-6
1957-1964 Jeep FC-150
$135.00 ea. plus shipping.
(https://i.postimg.cc/nLRSR4ZS/20260313_222359.jpg)
(https://i.postimg.cc/TP7N7VG7/20260313_222607.jpg)
(https://i.postimg.cc/VNGZGq17/20260313_222341.jpg)
Take out early 3B speedo I pulled from a 53' and has been in cold storage. Nice piece, I just don't need it anymore. Used it in another project for many miles and worked reliably. Will fit 2A and 3A or M38 or A1 if you wish, but not correct. Excellent shape for it's vintage and miles and comes with hardware as removed. No scratches on lens and bezel is in fine shape. If I was restoring a 3B, I would disassemble, roll it back and be proud to use it. It is not self illuminated (correct instrument lamp is below). $55.00 plus the ride.
(https://i.postimg.cc/Y2dMW299/20260314_180748.jpg)
(https://i.postimg.cc/v80bV8BG/20260314_180754.jpg)
(https://i.postimg.cc/L4x214XS/20260314_180758.jpg)
Takeout speedo from a M35 truck (I believe). In any case, will work and fit your 2A, 3A, 3B, M38/A1 or custom trail rig. CJ speedo cables will mate without a problem. Some scratches on lens but bezel has no rust. Comes with correct hardware and bracket as shown. $35.00 plus the ride
(https://i.postimg.cc/brVPcgM0/20260314_181414.jpg)
(https://i.postimg.cc/FzCv5pqj/20260314_181420.jpg)
Brand new Crown volt meter J8126659. Illuminated. Made in USA. NIB with bracket and hardware. I do not need it, and must have come in a mixed lot I bought. Some dust but will clean up nice. $38.00 plus the ride.
(https://i.postimg.cc/8kZN6kCq/20260314_180922.jpg)
SunPro voltage gauge. Looks to be new but without box. Dusty but will clean up fine. Made overseas. Needs light socket and bracket. $8.00 plus the ride.
(https://i.postimg.cc/h42cd4jz/20260314_180350.jpg)
(https://i.postimg.cc/y8cbHn33/20260314_180358.jpg)
Mechanical oil gauge from overseas. I used it, and functioned reliably as it should. Self illuminated with bracket included. I even found some tubing which included. Perfect for someone needing a functional gauge at low cost. $13.00 plus the ride.
(https://i.postimg.cc/J0Y8Vxgc/20260314_183930.jpg)
(https://i.postimg.cc/prcvbC7J/20260314_183936.jpg)
NOS 12 volt oil pressure sending units. I have two. Seal Tested and new in box. One has box, other one will not have box $28.00 each or $52.00 for both plus the ride.
(https://i.postimg.cc/bYGX5xgG/20260314_180546.jpg)
(https://i.postimg.cc/KcKXWPfR/20260314_180551.jpg)
**BOTH SOLD** NOS temperature sending unit. Seal tested. Unopened package as shown. I have only one left. $28.00 plus the ride.
(https://i.postimg.cc/YSPvNdXD/20260328_160353.jpg)
(https://i.postimg.cc/XvPrKs2x/20260328_160344.jpg)
Take out fuel sending unit. It worked fine when pulled. Empty reads 8.7 ohms at full, 80 ohms when empty. The arm moves freely and everything looks clean and shiny bright. 12 volt. Brass float. I believe to be older repro, like the tank it came from. I would use it for sure if I needed it $20.00 plus the ride.
(https://i.postimg.cc/wxtKrX2m/20260314_183152.jpg)
(https://i.postimg.cc/44KC06Ph/20260314_183144.jpg)
**SOLD** These are steel buckets (confirmed with a magnet) not the crappy zinc alloy units that corrode. Retaining rings and all of the associated/correct screws and washers are included. Trim rings are pitted and one has corrosion as shown. Mismatched headlights, one Westinghouse and the other Wagner (I can discard them if you want to save $ on shipping). Pulled from 58' CJ5. $45.00 for the pair as shown plus shipping.
(https://i.postimg.cc/q7vR7Jym/20260315_100438.jpg)
(https://i.postimg.cc/2595bs7h/20260315_100419.jpg)
(https://i.postimg.cc/1z3tzmwJ/20260315_100544.jpg)
**SOLD** Matching set of takeout throttle and choke cables, ready for another 65 years of service. They work as they should. Correct jam nuts are included. The knobs show some wear as shown. $15.00 for the matching pair plus shipping.
(https://i.postimg.cc/8P2ZyJNg/20260328_121604.jpg)
(https://i.postimg.cc/qMP1mh4d/20260328_121610.jpg)
(https://i.postimg.cc/7L1J1T1D/20260322_113915.jpg)
Canister oil filter, from 59 CJ5. Also correct for many 2A, 3A and 3B's. Clean in and out. Been through the parts washer with original patina. 100% complete with cover, filter spring, brackets, hardware (not cleaned) and O-rings. Small corner of bracket has been cut to clear a Monarch pump back in the day. I will include an unused Hastings LF130 filter to sweeten the deal. $45.00 plus the ride.
(https://i.postimg.cc/5tnJYM30/20251226_092851.jpg)
(https://i.postimg.cc/xqDVDj0y/20251226_092843.jpg)
(https://i.postimg.cc/8cL8qKdY/20260329_143058.jpg)
(https://i.postimg.cc/GhGHBHT5/20251226_092838.jpg)
**6 LEFT 4/19/26** Brand new (older stock) Hastings oil filters. Each comes with a fresh O-ring. Made in the USA. I've used these for a few years and love the fact that they have nice and tight rubber seals at each end of the filter. Some lesser quality filters do not have the seal on the bottom. Pictures below show dimensions and fitment. Date codes seem to indicate various 2003-2013 manufacture dates. I have about 10 to sell. $14.00 each plus shipping.
(https://i.postimg.cc/G2sHPp04/20260321_181103.jpg)
(https://i.postimg.cc/gJ6ny092/20260321_181147.jpg)
(https://i.postimg.cc/C1fzCKyd/20260321_181156.jpg)
(https://i.postimg.cc/rs56vnGY/20260329_142906.jpg)
(https://i.postimg.cc/6qCsDjVS/20260329_142926.jpg)
Both starter drives, both temp sending units, CJ-5 speedo, buckets and cables have been sold. 6 oil filters are left. Thanks to everyone for looking.....Pete
